Hi,
My 71 bug lost the clutch the other day, went for a short drive, reasonably warm weather, short trip at freeway speeds both ways, 10 minutes each way.
No problem until I pulled up at the lights off the freeway, pushed in the clutch and there was a noise, and then nothing, no clutch pressure.
I was able put it in 1st then the used the starter to get home.
I checked the cable at the pedals and it was still attached.
I noticed that the gearbox arm shaft has a small amount of movement where it comes out from the box, and a bit of movement side to side when the clutch cable was removed and with no pressure on it.
Start the motor and no odd noises.
So I adjusted the clutch cable at the box and it went right up to just about the full length of the thread near the cable and I had pressure on the clutch. So I spaced the lever and a locknut to just about upright and have about 20mm free play at the pedal.
Checked the car, pushed in the clutch and had pressure, started car went back and forth in the driveway all seemed normal with no odd noises.
Went out on the road with lots of gear changes, all ok, clutch felt normal, no unusual mechanical noises.
Box is a Scat pro street, car has only 2000klms on it everything is new, (not by me, previous owner)
I suppose I am hanging off doing what I must eventually must do and that is pull out the motor.
All ideas will be welcome.
Darryl
paslow22 ·
