Aussieveedubbers 路 Tech Talk
Electrical question
https://forums.aussieveedubbers.com/threads/112301/electrical-question
m4co 路
So I need more 12v outputs with Ignition but I don't want to overload the current output on the standard fuse box. I purchased another fuse panel and I am a little confused as how to run 12v Ignition to it.
Should I just add a connector to the back of the ignition switch?
I have drawn on how I believe that it should be wired up but I would like an opinion as I am not that confident when it comes to modifying anything electrical.
As the picture indicates I would like to run a cable from the ignition switch and connect it to all the tops of the fuses and then run any 12v outputs from the bottom. Is this an acceptable way of doing so?
Thanks 馃憤
AA003 路
Keep it as close as possible to the ignition switch as the ignition switch is not fused.
You could also piggyback it from the original fuse panel ignition feed.
modnrod 路
If you start drawing a heap of extra current, all of it still goes through the ignition switch........which is why the plastic bit melts (too much heat).
If that is the case, then consider adding a big continuous duty solenoid (fancy name for a relay) to then power up your ignition circuit. The switch then only carries less than 1Amp and will last forever. I can give you a diagram if you wish, or take it to a sparky for a stress-free upgrade for not a lot.
psimitar 路
The wire you use for the feed needs to be able to carry the current of all 4 fuses so with 4 x 8amp fues you have a maximum load of 32amps. So you use wire of the correct size to carry that much load. Second thing is the ignition switch now has to carry that extra load and it's not such a good idea to load the switch up that much as it makes it wear out quicker. Using a 40amp relay to feed the new fuse box would be a much better idea. The ignition switch truns the relay on and you have a live feed from say the light switch to the relay to carry the fusebox feed.
Daisy chaining 10amp wire will work but if you run too much amps then you'll set fire to the 10amp wire. It's better to be safe rather than sorry with electrics.
m4co 路
Thanks for the input guys, I knew it was a good idea to post on here!
I have made a wiring diagram based on your suggestions, does it look correct? I mostly plan on using the power for a cigarette lighter socket so I can charge my phone and power to a wireless Bluetooth speaker later on so I can listen to the radio without the need for a complete stereo.
Would 8 gauge wire be acceptable to use? I did some research and apparently it is rated to 40 amps
psimitar 路
The diagram looks spot on apart from the 12V feed to the relay. You need to use the thick red from either the ignition switch or the light switch. Depending on the year of vehicle will dictate which is best.
As for the 8 gauge, I usuallly use a cheat sheet to look it up but if it's rated for 40amps at 12v then all good. You could even wire it direct to the battery if trying to connect to the other wire I stated is troublesome.
psimitar 路
AA003 wrote:
psimitar wrote:The diagram looks spot on apart from the 12V feed to the relay. You need to use the thick red from either the ignition switch or the light switch. Depending on the year of vehicle will dictate which is best.
How about you let me know what model vehicle that you have and how many fuses the original fuse box has and I can design something really nice for you.
Um, I'm not the one wanting the extra fusebox so unsure why you quoted what I said? Confused?
AA003 路
m4co wrote:So I need more 12v outputs with Ignition but I don't want to overload the current output on the standard fuse box. I purchased another fuse panel and I am a little confused as how to run 12v Ignition to it.
Thanks 馃憤
m4co 路
Thanks 馃憤
It is a 1966 with 8 available fuses
AA003 路
One end of your fuse panel are large red cables that are B+. Connect a large red cable (4sqmm) from the top terminal to 30 on your relay. Keep this as short as possible as it is permanently live and not fused.
The other end of the fuse panel are black cables that are ignition live (15). Connect a thin black from the top terminal to 86 on your relay.
Run a small brown from relay terminal 85 to a good earth point. The black and brown only need to be thin as they have low load (around 1 sqmm)
Try to buy a relay that has 2 terminal 87. (Not a 87 and 87a). This will make it easier to connect multiple cables to your new fuse panel. You will then only need to piggyback 2 cables at your relay or fuse panel.
psimitar 路
I've not found an online supplier in Oz for uninsulated terminals but I use Vehicle Wiring products in the UK. Postage is pretty cheap and fairly quick, depending on AusPost. Anyhow, there you can buy spade terminals that can accept some pretty large cable sizes. Just makes doing double or even triple wire terminations to a single connector far easier. 馃檪
AA003 路
Actually I have all of the equipment to make a loom if you wish. Probably even supply a double pole relay. Postage would be the biggest cost.
