66 front beam clarification - urgent.
https://forums.aussieveedubbers.com/threads/112380/66-front-beam-clarification-urgent
KalgoorlieGreg ·
Hi all,
What front beam should a 1966 Aussie Standard have?
Mine has a King/Link Pin beam, which is damaged and needs replacing.
Found one in another 1966, but it's a Ball Joint beam.
What's going on? I know they aren't a straight swap.
Cheers, Greg.
Governor ·
As far as I was aware all had K&L till after 67?
vwo60 ·
Does it have four stud wheels all round and discs on the front end, 68 on have the ball joint front end but the US model had the 67 with a ball joint front end with 5 stud drums. Link pin and ball joint front ends are not interchangeable as they have different tube spacing. it would require the frame head change to fit the latter beam
http://www.clubvw.org.au/austvw001
psimitar ·
Aussies are terrible at whacking one year of body onto another year of floorpan and then say it's a whatever based on the body. If you look up the chassis number that will tell you fairly certainly what year floorpan you have and hence whether it should be a KP or BJ beam. Well unless someone decided to do a framehead swap but that's somewhat unlikely.
Oh, and whatever beam you currently have fitted. Well a KP/LP beam has straight upright shock towers that only angle towards the rear of the vehicle. BJ beams have the shock towers lean backwards and outwards.
KalgoorlieGreg ·
I have upright shock towers, drum brakes and wide 5's.
I don't know what hubs were on the other 66 beam I was looking at because they were gone. Shock towers were leaning out.
Both are 66 Beetles. Mine must be early in the year, his must be late and started using the different 67 setup.
vwo60 ·
68 was the first year of the BJ beam and 4 stud wheels, the 67 I had was LP and 5 stud wheels, if it has the BJ beam some one has changed the frame head, how is the pan, you could do a pan swap and use the BJ beam. swapping the pan is very straight forward.
KalgoorlieGreg ·
Pan isn't available. Only the beam was for sale.
dangerous ·
66 Euro bugs had ball-joint beam and wide five drums.
From memory the tie rods' taper and thread are smaller than the 68-on,
and the stub has at least one size smaller than the later ball joint stubs.
psimitar ·
KalgoorlieGreg wrote:I have upright shock towers, drum brakes and wide 5's.
I be surprised if someone went the extent of doing a frame head conversion. More likely it's a later entire pan under a 66 body. Doing a pan swap is extremely simple compared to a framehead swap. Not that I'm saying it isn't an option.
Anyhow, from what you've said you now have a BJ beam that is of no use to you unless you either change the pan to a BJ pan or do a framehead conversion.
If you really want disc brakes then for the LP beam you'll have to look at kits specifically for the wide 5 wheel bolt pattern.
KalgoorlieGreg ·
I didn't end up buying the beam. We spotted the difference before money changed hands, luckily.
I'll keep on looking for a LP beam. Not in a rush but would like everything sorted, just for piece of mind.
Massive thanks to everyone for their inputs.
AA003 ·
All 6v wide 5 Australian Beetles had king pin beams.
Ball joints were on 12v fully imported and CKD Beetles. ('68-'76 )
psimitar ·
KalgoorlieGreg wrote:I didn't end up buying the beam. We spotted the difference before money changed hands, luckily.
What's wrong with your current LP beam? Maybe it'll be better to rebuild it rather than get a second hand one that may need new bearings and seals too.
KalgoorlieGreg ·
Bent beam.
It's bent. You can't straighten pipe properly. It'll always be bent out of shape.
HappyDaze ·
Easy enough to straighten...I've done quite a few of 'em. 👍
All you need is a good quality chain, and a hydraulic jack.
psimitar ·
KalgoorlieGreg wrote:Bent beam.
Ah, I see. It could be straightened but unless you have the time, tools and experience then a good second hand one is definitely the simpler option 🙂
KalgoorlieGreg ·
I have the tools at work, but as it's a multinational mining company with restricted site access, I can't take it in!
And starting with a fresh beam let's me build it up while keeping the pan rolling.
psimitar ·
KalgoorlieGreg wrote:I have the tools at work, but as it's a multinational mining company with restricted site access, I can't take it in!
Yup, I know how that goes. All the best with your search 🙂
