Holden Red Coil
https://forums.aussieveedubbers.com/threads/112388/holden-red-coil
Growler ·
Howdy all. My 12v coil has died on my 69. Ive got a coil from a holden red motor in the shed. Can I use this or will I stuff something up?
should work fine
HS618 ·
The Holden "red" engine had 2 wires on coil (+), yellow which is a resistor wire and a black wire, which is a cranking override to provide 12 volts during crank.
The original coil is a RESISTOR type coil, needing an 8 volt supply. The voltage should be marked on the bottom of the coil.
AA003 ·
No you cant use it.
Growler ·
RightO, new coil time. Cheers
