Iv'e been driving this around for awhile now, but I want to nip it in the bud.
The starter solenoid clicks, the motor spins, it engages for a second, then lets go and spins. The solenoid remains engaged until I switch off ignition.
The flywheel is fine, no worn or missing teeth.
Any ideas?
southspark ·
Its your starter drive.
Regards Paul
ultrasuede ·
Is this what you mean?
grumble ·
Yes the overrunning clutch in the bendix drive or wear in the solenoid mechanism.
southspark ·
The teeth on the drive should be 90 degree not angled ,also check your ring gear right around, should be the same on all the teeth.
