For sale is my 1968 Beetle Convertible
It has had the convertible conversion engineered in Victoria but I do not have the engineering certificate. It has the required subframe underneath to support the pan.
Last registered in Victoria in 2005 - reg: SAC 110 (VIN: 197761851)
All rust professionally removed by a panel beater. It used to be red but previous owner painted it black (poorly) so there are a couple of places where the black paint is coming off and the red is showing through. Should be fine for a hot-rod type look, which is kind of where I was going.
Wide fibreglass wings with wide wheels to match - front tyres are 205/65 R15, rear tyres are 255/60 R15.
Stock drum brakes
Stock dual port 1600 engine, last started in 2015.
Offset rollbar to sit further behind the front seats.
Sports seats, possibly out of a Gemini(?). The seats are not mounted, the mounts are very agricultural and would likely not pass rego so you would need to look at doing something here.
Wiring loom is in place, just need the lights and switches fitted and connected (included).
Comes with all parts to complete the car (as far as I can tell) including soft top roof which I intended to not use - the only thing missing is a windscreen (and carpets, if you want them).
Price is set at $3500
Location is Jerrabomberra, NSW (15 mins from Canberra)
I don't really want to get rid of Black Betty, but I no longer have the time to commit to fix her up.
Contact Tim on 0419 158 106
Tim Bug ·
