Lowering a 69 lowlight
https://forums.aussieveedubbers.com/threads/112590/lowering-a-69-lowlight
mundymx ·
Have recently picked up a 1969 lowlight and im looking at lowering it. What's the best way to go about this? After some advice on what other people have done & if there is anywhere in Australia that sells custom lowing kits (narrowed adjustable beams).
Also wanting to convert to disc brakes on the front & after some advice on this also.
Any input would be greatly appreciated, Cheers.
waltermitty ·
Drop spindles on the front with late bay discs was a bolt on for my 70 lowlight. But yours might be different being wide 5. If i was you i would keep the drums if they are set up properly they are very good brakes. Also changing to discs means changing to narrow 5 stud pattern very cool feature for early bays INHO, unless you use a sherman or similar wide 5 disc conversion but that will widen your track and cause problems with tires interfering with the guards. So fix brakes good, spindles on front and turn a few splines on the rear good for 3 - 31/2 inch drop a still maintains good ride, and lower you start to talk big $ lots of mods and shit ride.
mundymx ·
Been looking around for drop spindles to suit my early bay window and it seems they are in short supply for 68-70 models. I have stumbled across these.. ( http://www.wagenswest.com/partstore/index.php/1968-70-dropped-2-5-inch-drum-spindles.html ) just wondering if anyone has used them before or could point me in the direction of any other brands, possibly cheaper options?
waltermitty ·
do you want to keep wide 5?
mundymx ·
Yea, wanting to keep the original 5x205 rims
waltermitty ·
Adjusters then. As far as i know (?) drop spindles are only for late disc brake front ends i updated my lowie to late when i installed the drop spindles.
I believe that drop spindles are the most comfortable way to lower and that any lowering more than 3 - 3 1/2 inches is not condusive to smooth ride.
Moderate lowering with adjusters will be fine
mundymx ·
Thank you for the input, looks like I might be going down the path of beam adjusters.
lolight70 ·
French slammers make dspindles for your model
waltermitty ·
lolight70 wrote:French slammers make dspindles for your model
tell us more
