So ive just bought my first type 3 - a '70 notch (28th Oct 1969 it left the factory in w Germany apparently!) its a project.
First issue is to get it going - it tries to fire with brakes fluid sprayed on the carbies but the old owner says the automatic choke blades have been removed (its not clear why) and its been sat outside for 6 months in all weathers.
I will put new sparks, leads, fuel and oil in but i figure without the choke im gonna struggle in cold wet Perth winter weather
So my question i guess is is it easy to source and fit a new choke - guidence welcome 馃檪
Will post pics asap
bushed 路
single carb or dual
what nr on carbside ...may have whole one to repl rather than strip and rebuild
or is just the heater coil broke or missing?
sugarlips 路
Thanks for the response bushed its a dual carb, engine number t071180, they are Solex so original VW german, i will try to see the numbers on the carbs in daylight tmw
I agree a whole choke system rather than recon is probably the way to go, how much would yours cost roughly please?
There are no air filters on it at all (thats how it came) but i doubt that would stop her turning over?
Im getting my mechanic to give it the once over tmw so that should help determine next steps..
vw54 路
get an original STOCK air cleaner and fit that
12 v new chokes are available are they wired up correctly there are several things to check
pv370 路
post up a pic of the throat of your carb....
from your post it reads to me as if the prev owner removed the butterfly.
its on held in by 2 screws which are punched over.
this is meant to stop them falling out and going through the motor.
(had it happen once ..... caused a hell of a banging in the cylinder it went into..)
see the pic below stolen off the net.....
are you missing the butterfly ?????
pv370 路
not the red arrows...sorry they were already in the pic
sugarlips 路
Thanks PV
Heres the engine bay for starters..
1500S 路
Makes it easier with it a bit lighter.
sugarlips 路
Thanks 1500s clearly im as technology challenged as i am mechanically haha
sugarlips 路
Close up of the wording reads: Solex 32-34 Posit 2..
sugarlips 路
pv370 wrote:post up a pic of the throat of your carb....
PV, seems you're right, no butterfly on eitherside...see pic
..if as you say they're only held by2 screws each, i should be able to replace and fit these myself?
pv370 路
easy enough if you can find the butterfly's (or would that be butterflies) and screws somewhere.
does the prev owner still have them ?????
if the carbs are good other than having the choke butterfy's missing then just replace the missing bits.
if the carbs are leaky, hard to adjust, or have very worn out bits then replace the carbs.
you may have trouble finding just the butterfly's.
maybe someone has some shot carbs somewhere????
sugarlips 路
Update: she runs!
After a week in dry storage with general fettling and daily WD40 finally theres life - enough to safely nurse her round the block, exciting times haha
I took a video but not sure if/how to upload?!
ACE76 路
You don't NEED the chokes in most Australian conditions, may just need to warm up for a minute or two. Auto-chokes can make eng. run too rich if don't open fully (and they often open much too quickly & then cause stalling). I used to de-activate mine. Some carbs have no chokes at all.
sugarlips 路
ACE76 wrote:You don't NEED the chokes in most Australian conditions, may just need to warm up for a minute or two. Auto-chokes can make eng. run too rich if don't open fully (and they often open much too quickly & then cause stalling). I used to de-activate mine. Someg carbs have no chokes at all.
thats very reassuring to know Ace, i should be aboe to take her for a freeway run then to get all the cobwebs out, as soon as it stops raining here
wombatventures 路
Find someone who can balance your carbs properly, I had the Notch done and it has never run so good. It's not something just any spanner monkey can do. Find a mechanic who has the right tools, and has worked on them before. Ask some of the local Perth VW guys, they'll tell you who to see.
If you need parts maybe try Denver - adlbeetle66, he has a pretty good stock of bits and pieces and I seem to remember spotting a couple of 32-34 Posit 2 and 3 carb parts in one of his photos.
We get minus 2-3 degree morning here and I wouldn't be without the chokes.
pv370 路
had a couple of -10 degree mornings here a few weeks back, the frost was an inch thick....................... trust me the choke comes in very handy then
sugarlips 路
Thanks for the advice Wombat, i have booked it in with Brooklands in Wangara they are aircooled specialists although they admit type 3s are not their speciality :/
If anyone has an alt recommendation for tuning im all ears 馃檪
