Dual carbretters
https://forums.aussieveedubbers.com/threads/112671/dual-carbretters
chokeau ·
Trying to use stock doghouse with dual webbers but can't get enough clearance unless I use empi garbage. Does an offset manifold exist, and if so where would I get them. Please exclude the moron at classic.
Yes you can get offset manifold
Give VVDS @ Campsie a call
Or look on websites like
air cooled.net
CB performance
Pierside
What carbs are you running?
If original old Webers you need the block off plate for the cold start circuit
Even with block off and offset manifolds you may still need to belt shroud with ball pein once or twice
psimitar ·
Try these guys https://www.vwheritage.com/ac1293168-cb-manifolds-offset-for-idf-drla-hpmx-carbs
I normally find that shipping costs are much less than the USA companies and exchange rate is good for the UK pound at present 🙂
I am sure VVDS will have what you need
