I bought this Formula Vee front end to fit to a hill climb special but have decided to go another route.
This is a link pin front beam with caliper mounts and discs. The calipers will need a rebuild as sitting for quite some time i think. The beam has height adjustment kit fitted with some of the leaves removed and also runs formula vee sway bar and shimmed to give camber. Comes with a nice tight steering box, 2 spare discs which will require small machining to fit conversion bearings.
The discs on the beam has has extra holes drilled at some stage to fit 4x100 PCD hence the extra holes.
Fit to your Vee or VW Beetle
I'm in Winmalee near Springwood.
Asking $450 ono
0439 593 407
sprite2002 ·
