All,
I'll post piccies once I take them and post to somewhere that is not PhotoB (like all my other pics馃槵).
Single Dell 40mm. Rebuilt using parts from CB/Alfa750/Dell UK. IIRC (I will check) 32 vents, 52 idles, 33 Acc pumps, 122/.2/180 main,tubes, air. Everything within spec. Last time I checked - no dell drip - but that was years ago.
$300.00 - SOLD
CB Perf air filter (like K&N) with a heavy cast bottom & tap.
$50.00
Carter Rotary Elec Fuel pump. Low pressure version. Dunno where the two wires went but you can order them from Summit etc. SOLD
ctefeh 路
DRD 5.4" VW I Beam rods - bushed
$150.00 - SOLD
ctefeh 路
AA 88mm slip in case/Machine in Head (1776 size).
4 Barrels, 4 pistons, 4 gudgeon pins, 4 pairs circlips & 4 sets of rings.
The pistons/rings/gudgeon's/circlips are 1 unit, so 4 units in the box.
PICKUP ONLY - they are HEAVY. Maybe I can get a flat rate courier quote since Au$Po$t will slaughter your wallet. Tentatively sold
$250 - Post/Courier (if possible) will add mightily to that
ctefeh 路
Spare 1600 donk - I will throw in the distributor & carb (carb is useless, top is good). BUT I will take off the semi auto flexplate/gland nut and leave the aluminium degree pully.
Built by SteveVW on this forum
It does not have - Oil cap thingy & gland nut for that, tinware other than cylinder covers, thermostat etc.
I'll throw in a wheeled dolly as well - best not hope to transport it on said dolly - shed duties only.
$500.00 - SOLD
ctefeh 路
Pierce/Weber single manifold. Has the best pre-heat for singles. The sticky photie shows the pre-heat side.
This is a right POS. The mount drillings for the single Dell or 40mm Weber are off. One tube has a slight ding (right hand in the pic"and will need some judicious beating. As you can see, new manifold boots & throttle cable. I test fitted the carb listed up above and the linkage is correct and all there. Just the drilling of the mount holes. I'll leave my welded & clamped bits on it for someone else to apply some skills.
$50.00
ctefeh 路
VW 30Amp gen. OK cond but no woodruff keys.
$40.00
ctefeh 路
Bosch SR17 starter (Autostick). With a mostly spare one. The spare has a broken actuating lever. - SOLD
$50.00
So, this will be first in, best dressed - And I'll watchfull of date/time anything sent or replied to. I will be MIA between 25/05 and 06/06. I really do not want to post a lot of this as it'll be at YOUR expense + purchase price. Pick up OK, but I'm not home till after 7pm most nights and working Sat Night/Sun mornings.
ctefeh 路
Marked things as SOLD Or Tentative, lowered prices on some items to reflect a little reality.
SOLD Thus far :
CARB
REGULATOR
CARTER FUEL PUMP
ENGINE
STARTER(s)
RODS
P&C kit - tentative
All have Dibs on them.
Some of the weightier items I can send via flat fee courier. Drop off point is near my home anyway.
Ctefeh
karmannghia60 路
What price do you have on the barrels and pistons?
ctefeh 路
Karman,
Can't believe I forgot to add a price. $250.00.
28.95 by courier, provided you live in a major city etc. 11.00 addition if you don't. Signature on delivery or drop off at a participating BP servo if I read their T&C correctly.
Regards
Ctefeh
ctefeh 路
The weighty items prices "appear" to be up-to-10Kg (max $22.00), then over 10kg up to 25kg. Then if you live remote from a big city/their delivery sphere - add on $11 more. To give you and idea - the piston/barrels weigh in at 13.5 Kg - which is over 10kg, so 28.95 flat fee in a city : +11 more if you live (IDK - Mt Gambier? Cunamulla?) outside that.
Signature on delivery, and If I am reading this right - alternative drop off at a participating BP servo or newsagents where applicable.
Ctefeh
ctefeh 路
So - I''ll start a new topic when I am back and have found more stuff, as I was editing the first post to update it and lost the info on some of the stuff...and can't put it back? Oh well........
Last real item is the Scat C20 Cam (dished) with riveted on gear - $70.
