Pan panel wanted
https://forums.aussieveedubbers.com/threads/112870/pan-panel-wanted
cnfabo ·
Hi guys,I can't post pics up so excuse my bad description lol...I'm after that metal strip that is on the under side of the pan where the frame head meets the front ahh firewall section....I see alot of pans don't have it but mine does....I need to replace it......if anyone could attach a link to the part I need just so I can confirm that's what I'm talking about?? And then someone might be able to tell me where I can get it from..
Fabo
what year model
cnfabo ·
Oh jeez I don't know..Has no chassis number on it.. Come with early roller pedals and the correct mounts on the floor... The beam had left hand drive steering box lugs on it but none for the right hand drive too...
BlasterTheRedBajaBug ·
Do you mean the section in yellow or the section in red?
cnfabo ·
Yellow but your scribble is a bit wide.. Mine is a separate piece running from the two bolt holes 100mm wide over to the other side..
Sorry about that, my baja pan had the same piece, the front bar was mounted through to there. This is a US pan so it will be slightly different as well.
M
cnfabo ·
All good I'll just repair mine...
http://www.justkampers.com/113-701-311-b-frame-head-bottom-plate-for-vw-beetle-1966-1998.html
this may be what you are looking for?
Hope this helps,
M
cnfabo ·
BlasterTheRedBajaBug wrote:http://www.justkampers.com/113-701-311-b-frame-head-bottom-plate-for-vw-beetle-1966-1998.html
Hope this helps,
M
Nah that's the whole bottom of the frame head skin... All dude cheers for the help...
All good, I can't really find anything that is just that specific piece.
M
cnfabo ·
BlasterTheRedBajaBug wrote:All good, I can't really find anything that is just that specific piece.
M
Yeah weird isn't it..it would be a common place to rust on whatever year pan I have...
