Cb wide five wheel bearings
https://forums.aussieveedubbers.com/threads/113020/cb-wide-five-wheel-bearings
cnfabo ·
Hi guys, can anyone point me in the direction for bearings on my cb wide five drop spindle brakes.. Went to statewide bearings but no luck there...
Fabo
Perth
vwo60 ·
Bearing will be readily available , just need the numbers from them and get them from a bearing shop, it might require removing a wheel and getting the bearing numbers.
cnfabo ·
I took the bearings into a bearing shop and they said nope.. Maybe he wasn't interested.. I'll try another place
modnrod ·
CBC bearings have a different set of suppliers than Statewide, worth trying.
vwo60 ·
Have you measured them, they have a metric bore, what is the OD.
grumble ·
I had the impression that they were kombi bearings as they used the kombi drum but not sure of the spindle size as they were a combination.
cnfabo ·
Pain in the arse just for some bearings isn't it... Bernie from Munster garage over here in Perth has sent a request to his bearing supplier for me... Cheers bernie
