After some help. I have a stock 1300 single port that doesn't miss a beat. I would like to add a drop in electronic ignition. The distributor is a vacuum advance bosch ju4r8 0231147002 111905205m. Can anyone recommend me one that they have used with success and who they purchased it off. Any help would be great. Cheers
binner ·
I have used HotSpark in the past without any dramas. Or try Pertronix.
GL
hulbyw ·
I have been using a Compufire for years. I found I needed a little loctite on the hold down screw in the dizzie. Beats adjusting and changing points any day
1958kafer ·
Do you need to change the coil as well or is the standard 12volt fine?
