What part is this?
https://forums.aussieveedubbers.com/threads/113240/what-part-is-this
viiking ·
I have diligently bagged and tagged hundreds of small parts for my body off 68 resto. Except these.
I thought these were front or rear body pan washers, but the holes have countersunk holes like they take a flush flat countersunk screw.
The washers look exactly like pan washers except longer and two holes.
beetleboyjeff ·
Pretty sure that are the balance bar on your handbrake lever, which evens out the handbrake cable lengths a little. You only need one per car.
Yogie ·
I second Jeff's conclusion.
Yogie
viiking ·
No unfortunately not. Those are tiny. These are about 2x the size of a body pan bolt washer. Same thickness.
pv370 ·
viking is right...the holes in the handbrake balance bar are bigger on the outside for the cables and small in the middle for the pin on the handbrake lever.
i am only schooled in type 3's and i cant say they look like any type 3 part ive ever seen. so must be beetle only ??????
viiking ·
Solved the problem. These are the pan washers inside under the back seat.
is there a folded lip on them and why are the 2 outer holes there
viiking ·
They are folded exactly like a body pan. I might have it wrong now as I can't explain the reason for the two countersunk holes. Will have to keep looking. It might become obvious once I start putting the body back on the pan.
