Aussieveedubbers 路 Type 3 and Karmann Ghias
Subi conversion # 3
https://forums.aussieveedubbers.com/threads/113391/subi-conversion-3
binner 路
So. ..... I ended up keeping the ute and have got some energy to put into it....
This will be a EJ20 install with the usual Aeroflow hardware and some sweet sandrail inspiration for the radiator. Had to fab up some struts to stiffen up the gearbox.
I need to make a false ute floor to accomodate the height of Subi manifold and throttle body...running hard line fuel line from front to back and return to tank....al fun stuff 馃槀馃お馃槀
binner 路
Struts....
1303Steve 路
Nice work, rear mounted radiators can be a challenge to get working right, see how you go
binner 路
1303Steve wrote:Nice work, rear mounted radiators can be a challenge to get working right, see how you go
do pre tel......
what have been the issues ?
1303Steve 路
overheating, you cant rely on thermo fans, you need forced air flow when at speed
1303Steve 路
also the Type 3 spare wheel well is the perfect spot for a radiator
11CAB 路
My Kombi ute with 3.8L V6 had the radiator in the back of the tray, lost half the space of the tray and the engine ran hot as well.
