Slight Engine Popping
https://forums.aussieveedubbers.com/threads/113463/slight-engine-popping
paslow22 ·
Hi,
When I come off the throttle down a hill for example the engine gives out some slight popping noises.
My idea would be carb mixture settings.
I'm running a 1915, and twin 40mm Empi's.
What do others think????
Thanks.
beetleboyjeff ·
An exhaust leak will often cause that
paslow22 ·
beetleboyjeff wrote:An exhaust leak will often cause that
Thanks,
I'm pretty sure there are no leaks but I will double check.
REDKG ·
Inlet leak
paslow22 ·
REDKG wrote:Inlet leak
When I changed the manifolds using new gaskets I'm sure I tightened them all up tight, I'll double check.
Hope not, because it's a bugger to get to No.3 nut.
if its popping it is unburnt fuel in yr exhaust I would be checking the jetting
paslow22 ·
vw54 wrote:if its popping it is unburnt fuel in yr exhaust I would be checking the jetting
To rich or lean?
I would say rich
You need to have an analyzer up the exhaust
the EMPI carbies are not very good as well.
grumble ·
An exhaust system with insufficient back pressure will also cause popping on deceleration, this was fairly common on the extractor systems with the hot dog muffler which would do a couple of pops and then an almighty boom and flame out of the pipe. Very effective at night.
paslow22 ·
vw54 wrote:I would say rich
Ok Thanks, The empi's were on the car when purchased.
paslow22 ·
grumble wrote:An exhaust system with insufficient back pressure will also cause popping on deceleration, this was fairly common on the extractor systems with the hot dog muffler which would do a couple of pops and then an almighty boom and flame out of the pipe. Very effective at night.
Car has a Fatboy muffler, maybe the cause?, I guess I have a few things to check up on. Keep me busy anyway.
Thanks,
Darryl
paslow22 ·
Thanks,
Darryl
Latest, Disconnected all carb linkages and re set carb and air/ mixture and it seems to have solved the popping.
Thanks for all the input.
Darryl
