Hi I am rebuilding an old open wheel hill climber and need a little help please.
The rear wheels are beetle hubs. I have attached pictures. The rear axle is fixed (no diff). My first question is whether there is a lighter weight option for the hub.
I already have 13 inch custom beetle rims so if there is an easy swap where I can use the same wheels that would be good. But it is not a major issue. My second question is the drive shaft from the sprocket to the hub is missing.
Do i simply buy a complete drive shaft with CV joints. The hub takes 6 bolts and the sprocket mounting plate also takes 6 bolts.
My third question is the distance between the hub and sprocket is 11.8 inches so the drive shaft would need to be cut and joined. I assume if done professionally that is not an issue.
Thanks for any advice regards Andrew
andrewl ·
