Weber 32/36 DFEV carbie with 'deluxe' intake manifold (ie pre-heat all the way up to the carb base) and custom made airbox with filter inside.
This carb gets a bad wrap! It works brilliantly when setup correctly. For those that know, John Connolly is the guru on this, and I followed his guide to set mine up.
https://www.thesamba.com/vw/forum/viewtopic.php?t=386388
The preheat tube on the right hand side needs replacing, but besides that the manifold is in pretty good condition and as mentioned has the preheat channel all the way to the carb base (to prevent icing).
http://vwparts.aircooled.net/Deluxe-Center-Mount-Progressive-DFAV-DFEV-K1410-p/deluxe-progressive-kit-k1410.htm
The airbox was designed by a mechanical engineer (me) and professional fabricated including powdercoating.
Only reason for removing from the car was that a pair of dual carbs came up that I couldn't refuse. The Weber is great upgrade over a stock Solex. Sure it's not as good as dual carbs but also way easier to setup and cheaper too.
$250 not negotiable
Pickup in Nundah, Brisbane or can post at your expense.
lauzboy ·
