Looking for 8 x Type 3 standard lug bolts (longer thread than beetle lug bolts)
Required because I have installed type 3 rear brakes.
Can pm me or contact mob # 0413845298
I may be wrong
ive had many Type 3s over the years and dont remember seeing longer wheel bolts
Its does make sense what your saying especially with the later 2 piece rear hubs and drums
Good luck with your search
I suggest that you remove one hub and drum then fit a wheel with a Beetle wheel bolt or what ever you have and see how far it protrudes through
Safety length would be 1 1/2 threads protruding
I have a box of wheel bolts and will check them to see if any are different
AA003 ·
Part number is 251 601 139 M14 x 19mm
They are the same for 12v Beetle and T3 Kombi.
You could also buy the screw in M14 studs that Nice Products sell and then use Kombi wheels nuts, much easier when changing wheels
hulbyw ·
I have run Type 3 rear drums (4 x 130mm) for many years without issue using the original Beetle wheel bolts which are 37mm long overall and have a 17mm head. I always tighten the bolts with a torque wrench
HOWEVER I just checked as Dave suggested to the OP and found that the bolts only just protrude through the back of the hub when done up tight but not torqued. Definitely not 1 1/2 threads protruding! And that is with OE drums!
Now to add to the problem, my new Brazilian drums (a brand recommended to me as being good quality) are around 6mm thick on the wheel face (OE are around 3mm thick)
So I strongly suspect (and hope) Type 3 wheel bolts will be longer than Beetle ones. Watching this thread with interest!
AA003 ·
hulbyw wrote:So I strongly suspect (and hope) Type 3 wheel bolts will be longer than Beetle ones. Watching this thread with interest!
There is only one part number listed on ETKA,
checked my wheel bolts today
68 on there all the same length as per Phils check of the parts listing
hulbyw ·
Interesting. My Type 3 brakes are on a '68, however the OP didn't specify what year he wanted the wheel bolts for. Maybe wide 5 are different?
grumble ·
hulbyw wrote:Interesting. My Type 3 brakes are on a '68, however the OP didn't specify what year he wanted the wheel bolts for. Maybe wide 5 are different?
Wide 5 are a smaller dia bolt.
REDKG ·
Early wide type 3 brakes use same bolts as earlier beetle, as fitted to my KG. Aftermarket wheels may need longer bolts or stud and nuts. Later had larger dia bolts.
Grasack ·
Thanks Guys for replies
I have new drums put on and they are the thicker type as hullbyvw suggested.
I am running after market sunraysia type wheels with 6mm metal plates and standard beetle bolts do not give good purchase, only 3-4 full turns where as standard wheels take 7-8 turns.
I boought some bolts from Lugnuts Aust that were longer but they only have 17mm heads (later VW lugnuts I think) and they are 2mm diam smaller than original bolts at the head of the rounded area (therefore less purchase on the wheel
See photos attached and you can see the wheels I have on the car, the difference in the purchase of the nuts on the wheels, the difference in the lengths of the bolts and the position the bolt would would purchase on the hub. I would much prefer the bolt extended out past the back of the hub for more strength.
Grasack ·
more photos
Grasack ·
last one
convert to studs using as per Steve suggested
i had similar on my 65 bug
Are wide 5 Bay Window wheels bolts any longer?
AA003 ·
You need to find out what the taper is on the wheels first. Those two bolts have different tapers.
Grasack ·
Thanks again for your ideas. I was under the impression that type 3 bolts were longer than beetle ones. But I was mistaken
However I will end this topic and go and check out the above options
HappyDaze ·
That's good - I'll be able to sleep now...😉
Greg i seem to remember something about a rear brake drum a few years ago
