Timing Lights
https://forums.aussieveedubbers.com/threads/114032/timing-lights
AA003 ·
I need to buy a timing light. Any recomendations?
Battery or 12v?
LED or Xenon tube?
I just want something reliable so would prefer LED. Anyone had experience with these?
BoogieRider ·
equus 5568 - nothing more nothing less , volts , adjustable timing to check total advance , rpm -the standard
Phil
This is my timing light pretty basic but works every time
The crocodile clips work well
make sure you have the correct voltage globe in the system
BoogieRider ·
vw54 wrote:Phil
bloody hell Dave , Jesus must be pissed you never gave the donkey kick starter back lol
Oh forgot no battery required
AA003 ·
vw54 wrote:Phil
It's pointless.
BTW I have the leds for the blinkers connected. they are BRIGHT! I now have 3 warning lights and 2 buzzers. I won't forget to cancell the blinkers.
grumble ·
vw54 wrote:Phil
Ultra reliable Dave, I have used one with a probe in place of 1 crocodile clip since I started my apprenticeship in 1966 & it has many other uses too.
AA003 ·
Surely someone on here has an electronic distributor?
I didn't think anyone used points.
Points R perfect
very useful tool Grumble
Phil How did you go with the negative earth for the blinker
AA003 ·
vw54 wrote:Phil How did you go with the negative earth for the blinker
Just wired it how I said. Just ran a wire to the relay/indicator switch. When the flasher is off the light turns on (earths through the blinker globes) It is BRIGHT!
HappyDaze ·
AA003 wrote:
vw54 wrote:Phil
It's pointless.
Then why did you do it?😂
