1915 VW versus 2.5 V6 versus WRX motor
https://forums.aussieveedubbers.com/threads/130/1915-vw-versus-25-v6-versus-wrx-motor
Baja Wes ·
Baja Wes
For those that wonder about the differences in power and performance of the three, check this out;
http://www.offroadvw.net/bajawes/V6_baja/compare.html
blue74l
I dont understand Wes ????
I know a few 1915's (Greg Ward for one) and man....that puts a shitload more than 100 HP out.
I know a few Rex's and NO-ONE runs ULP
For MY taste i would have the sound of the Webered 1914 ANY day
I would rather rebuild a VW motor over either the clips anyday
ok...ok...just not my cup of tea.........maybe we need a "conversion perversion" section
Have fun anyway
Baja Wes
The HP curve for the 1915 was taken from a Hot VW's dyno test on a 1915 with unported Street Eliminator heads, twin 44IDF's and everything else very similar to my car. So the HP curve for the 1915 is about right.
I know greg and CT have a lot more HP out of their 1915's, but they have spent a lot more than $2500 on them.
The 1915 sounds good for a vw motor, but it has nothing compared to a nice high revving jap V6, or the growl of a wrx.
The vw motor is 30's technology, it is now 2002 and it's about time we move forward and embrace todays engine technology
I had learnt almost all there is to know about air-cooled engines, and my brain wanted a new challenge. Now I am learning everything about EFI engines and loving it.
blue74l
Yep....cool....
Che Castro
yeah the type 1 and even type 4 engines are archaic, but i still think it's amazing how much power can be extracted from them
Blown T three message deleted cos he is being very weird and acting in a criminal manner
Baja Wes
The VG30 is too big to legally put in a beetle/baja. The 13B has absolutely no torque down low, and would be way worse than the suby motor in the low down torque area.
I was originally going to build a supercharged type 4, until I started costing everything and realised how expensive such an impractical engine would be. Even if you do it yourself it would cost silly amounts of money. You would be hard pressed getting the cost of the EFI below $2000.
Baja Wes
yes but even if you get it to work you still only get a primitive form of fuel injection, and the computer still won't control the ignition which you need it to do if you want to get the most from EFI. The EFI on the dune-buggy site is pretty rough, I speak (by email) to Todd sometimes. He has alot of knowledge.
Do you have a VAF/MAF or are you going to use a MAP? Either of those aren't cheap.
You'll have to size and buy correct size injectors, I imagine the commodore ones will be too large.
The EFI on a newer car's engine controls more than most people can imagine. If you go supercharged/turbo charged you would want a knock sensor and control in the ECU too.
The mazda engine also has, climate control air con, decent heating, variable resonance intake system (gives the broad torque band), knock sensor / control, air temp correction, air pressure correction, 90 amp alternator, direct port injection, and other goodies I can't think of right now. It seems silly to me to try to modernise an ancient vw motor when you get so much more for so much less from a jap motor.
But I would love to see your motor when your done. I would love to go for a drive in your car and I'd love to take you for a drive in mine so we can see the real world difference of the two styles of motor. each to their own
kruizinkombi2
Very good page, Wes. Keep it coming.
Its probably not my choice of engine, but your rationale is sound and your research is excellent.
Colin Richards kruizinkombi@msn.com
Bug racer
I would have put a VR6 motor there . Or an Audi motor , just as long as it's VW !!
Baja Wes
trying ringing around importers and getting a price for an Audi or VR6 motor and you'll see why I didn't go for that option.
The problem is wes is that you have a baha!
I saw a bug that had a WRX in it at the Nationals last year and ....man the cut in work for a full bodied bug!....
Yeah i can see your point on some things but a 2007 is still my dream.....and i can do it for under $2K as well.......
Wont have 044's that are fully worked but it will be potlically UN correct :P
Baja Wes ·
sleepe3, I didn't knock rotaries, I just said they have no torque down low compared to the V6, which they don't. It isn't an opinion, it is a fact. A 13B would be crap for serious offroading.
Blue,
I think if you build a 2007cc for under 2K you will be disappointed with the performance. It wouldn't go any better than my 1915. The extra 92cc won't make up for the stockish heads you'll have to run to keep the price under 2K. I'm not trying to knock your project, I just hope your being realistic about your goals. Maybe you can take me for a drive one day when your finished, and I'll take you for a spin in the Baja.
"I just hope your being realistic about your goals. Maybe you can take me for a drive one day when your finished, and I'll take you for a spin in the Baja."
Your on!
Nah i am realistic - my $400 special has a few holes with blow by in my 90.5's but Mick Motors will fix that for $435! :P
I hope to pick up a 78 for $500 or there abouts. Yeah ...no 044's but i reckon it will go but it will still be "stock"
I would LOVE to see your project when its finished but i guess i am a cheap skate that takes the easy road.....
My 1776 with HD clutch and IDF's has come in under $2500 so far .....put $$800 aside for the carbs and i will just be over the $2k mark for the stoker........
I just like "old school"
Are you taking piccies of the project?
Baja Wes ·
Yeah I'm going to be taking pics as I go. I will be busy for the next two weeks getting the Baja finished off and clean for the Action Day show. I still haven't finished under the bonnet or made a proper bonnet latch yet.
You can follow the V6 transplant story at
http://offroadvw.net/bajawes/linktoV6.htm
Wes
just had a better look at your site where you do the over lays.
The weight of the flat 4 is MUCH lower than the V6. You reckon this is going to give you any "centre of gravity" problems - specially seeing it is in a baja?
Hey - you never mentioned any thing about the $1000 for the adapter plates in your cost comparrison did ya 😀😀....yep interesting project but i will be interested in what it costs you in the end?
You selling the 1915 to finance this?
Baja Wes ·
BT_3,
It was meant as a joke, cos you posted stuff and then decided you didn't want it posted so deleted everything to hide the evidence.
David,
That's a pretty wild baja, but it is designed for a different form of offroading to mine. American offroad baja's do high speed desert type offroading where you don't need torque down low. Australian offroad baja's are different and are used in tight bushland where you need low down torque. That's why I'm going a V6. If I wanted outright speed I might consider a rotary, and some ear muffs 😉
twobus ·
I know it isn't a VW but iv'e got an extended port 13B rotary in my mazda E2000 twin cab truck which has a GVM of 3000kg and it doesn't have a problem with being gutless!
180 bhp @7500 rpm is still 180 bhp. an auto trannie helps but 90k/h in first 140k/m in second and I don't know what in top is OK by me. (my son wants me to put the 13b in our splittie but theres no way)
Forgot to say that the 13b new from the rebuilders ex rx7 twin turbo with high compression rotors fitted and turbo's removed
was Exactly $2000.
[Edited on 29-8-2002 by twobus]
Baja Wes ·
BT3, maybe I should put it in simpler terms.
100HP is all you can expect from a vw motor for $2500. Pobjoy 1915's make about 100HP and cost $3000+. I am comparing engines of a similar price. I know there are more powerful vw motors around, but you couldn't expect much more than 100HP for $2500.
A V6 commodore sounds crap cos it is a family car. Listen to the next FTO you see go by. It too has a small revvy V6 and has been described by many motoring journalists as one of the best sounding engines around.
When you tried to calc how much the Baja weighs from acceleration times you forgot about aerodynamics. That's what slows a baja.
As for air-con robbing power, I won't care when I have 200HP.
Baja Wes ·
And again, as said before;
I never said rotaries were gutless, they just don't have as much low down torque as the V6.
twobus ·
Well I suppose they don't have much low down torque! but that is what gear ratio's are for.
Although I do concede that they're no good for chugging about, but if thats your cup of tea!!
Baja Wes ·
yeah I know sleepe, thanks for the link, it was a cool baja.
He just has different objectives to me that's all. 😎
Bugged Again ·
just cecked out your engine pictures and the V6 looks longer than the vw, does that mean you'll be chukking wheelies down the street:o
you'll have to get wheelie bars fitted!
look forward to seeing it at the show
Baja Wes ·
BT3,
all you are doing now is showing how little you know.
Do you know how deep a type 4 engine is? The same as the V6. Whoa look-out better not put a type 4 in a beetle the sump will drag on the ground.
Pobjoys base engine makes 100HP. He has fancier versions but they cost more. another aust vw shop made a 200HP turbo vw motor, but it cost $7500 in the mid 90's, so more now.
Yes the V6 is longer, but only marginally. the parts that are longer are timing belt and accessory pulley which don't weigh much. The center of gravity won't move much.
Guys I have spoken to with MX6's say the V6 weighs 250lb. A type 4 weighs 250lb. whoa better not put a type 4 in a beetle, it will be too heavy.
All those things you listed, I will do myself. It won't cost me much. The overall price will stay around $2500. I will sell at least $750 worth of stuff from the half cut.
Plus I already have a bigger trans, trans mounts and CV's ready to handle the extra torque.
You can delete your posts now.
Baja Wes ·
deep meaning from centerline of crank to the bottom of the sump. Yes a type 4 and a V6 is about the same.
So you think you can build a 200HP turbo vw motor that is reliable for under $7500. I'll believe it when I see it.
Yes I am making my own adaptor and flywheel by the way. Even if I bought them, the total price would stay under $2500.
Why would you rechip the computer, the standard one is fine. You don't need to rechip the computer on a EFI car just because your running a different exhaust and air filter. Don't you know anything.
I was refering to the COG moving backwards. It won't move back much if at all. Moving it higher is fine, it is a Baja with a 2inch lift kit, the engine conversion will make hardly any difference compared to the mods already made.
I too doubt the 250lbs, but I will weigh it when I have it out by itself.
Your obviously just a very close mind person. I like all engines, whether they were made by VW or not doesn't matter, they are all internal combustions engines. I wrote the advantages of each motor. The VW motor has advantages, but I liked the V6 advantages better. I have nothing against any engine. And you call me bias
Monsterbus ·
A 2.0lt kombi box survived behind my 230hp V8 in the Kombi. Did end up replacing the ratios though for better performance. The Kombi weighed close to 1900kg I also ran 235/75/15's on the rear and had no trouble smoking them up if I wanted. Those Kombi boxes are tough. In a liteweight like the bug It should cope no problems at all.
Of course this is from my own experiences with a water colled V8 swap into a Kombi 😉
P.S Good luck with it Wes, I personally think it'll be a great swap.
[Edited on 30-8-2002 by Monsterbus]
Baja Wes ·
Thanks heaps Steve. I think the kombi box will be fine too. Especially if I stick with a relatively standard clutch and don't drop the clutch at 8000rpm
I still like VW motors. I am currently helping a friend build a turbo 1600 with a rajay turbo. We got the whole lot for $1000. It should be good bang for his buck, and is going in a lightweight manx as a street car. The same turbo 1600 would suck in my Baja. But we are realistic and know that we could not build a cheap 200HP turbo reliable VW motor. Not on our budget.
[Edited on 30-8-2002 by Baja Wes]
Che Castro ·
hehe as the saying goes,
speed costs money, how fast do you want to go?
baybuscamperkid ·
1. Buy a bus, not a bug - $500
2. buy a subaru 2.5l - $2500
3. buy a conversion kit - $400
Burn rubber with a flat four that has REAL power!
Buggy Boyz ·
I think teh issue here is approach, Wes is talking $$$ comparison to achieve HIS AIM which is clearly to try and keep up with my Buggy. Now he can't go as high or track as well so he is simply going to go faster so him momentum carries him through.
As for the VW and power sentence... have a listen to what you are saying ... how much VW do you think there actually is in a $7500 VW motor, not much let me tell you. In fact there ain't that much in a $2500 VW engine. If you change the crank, rods, piston, manifolds, exhaust, clutch, dizzy, heads, valves etc etc etc ... when does it stop being a VW ???
Bang for your buck a water cooled engine wins hands down.
I don't reckon there is to many on here whop actually own / drive a pure VW so who defines the line ??
555bug ·
<jedi hand wave>Real knowledge is to know the extent of ones ignorance<end jedi hand wave> =:-}
Baja Wes ·
Smegma, Would you have that guys number? I would be interested in talking to him. I'd like to see some pics and details on your project too.
100HP in a beetle is heaps faster than 100HP in a baja. The baja is heavier and less aerodynamic. My 1915 was in an L bug first, and it was much quicker in that. The Baja definitely lacks go at highway speeds. It'll out run an old holden with a 202, but it will get killed by my brothers pulsar Q over 100kph. So I don't think 200HP will be completely insane. It will just be real nice.
As for the price, you either get things done with money or friends or hardwork. I have a lot of friends and am willing to do a lot of hard work. So I will keep the cost down. At the moment if all goes to plan it will stay under $2500. I'm a smart boy and plan on doing almost everything myself. But time will tell. I am keeping a running cost list on my website so everyone can see.
Baja Wes ·
BT_3 wrote:As for water cooled engines winning hands down, have you ever followed lemans 24hour racing ? porsche Aircooled motors absofrickenlutely raped everybody to the point they were almost banned, if anyone thinks schumacher/ferrari is dominating F1 then they should look at Lemans, try almost 16 years straight, yeah baby aircooled motors kicked some arse.
Man you seriously need to get your facts straight before saying such silly things. Porsche has been using water-cooled heads in their race cars since 1977. And despite the fact Porsche 4 valve a cylinder technology is a hell of a lot different to the ancient vw technology.
volksrodder ·
This discussion is getting stupid, its his car he can do as he pleases. The secret to every good car is the evolution of its bits, if the modifications suit him then thats great, he's not forcing any one else to do it. As good as Vw motors are they do tend to get high matinence and temporary when used for maximum fun. Icruise so i use stock parts. Please stop the narrow mindedness and congratulate the guy for having ago, after all ferdinand porsche used heaps of engine combinations in his early prototypes, whats wrong with us doing the same !
Che Castro ·
hmmmm... i think that doing such an engine swap like this takes a lot more guts. It will cost a lot less and last a lot longer, no argument.
Aircooled VW motors are antiques. An air cooled porsche is entirely different. Have a look at what about 40 years difference in technology can do. As far as i know Porsche air cooled engines don't really suffer from dropping exhaust valves.
Porsche used DOHC in the 50's. Porsche used one head for every cylinder as well. Porsche motors have developed and improved over time, whereas Aircooled VW motors remain essentially the same as their predecessors in the 30's.
jon
Baja Wes ·
yeah I agree Jon. :thumb
I know some people are getting sick of the silly ongoing arguement in this thread, but everyone seems to be viewing it, so someone finds it interesting 😀
The thing about this conversion is I like it, and all my friends who I respect like it, and that's all that really matters to me. The purpose of this post was just to let people interested in similar conversions to see the differences of the various motors and make up their own mind as to which motor best suits their needs.
The fact that someone like BT3 tries to argue the idea is bad, and lacks the intelligence to put forward any logical reason is just funny to me. Finding flaws in his childish reasoning is good fun 😎
Che Castro ·
hehe i don't see why anyone else would really discourage someone from doing it if they know what they are facing... i mean it is YOUR car!
personally i would prefer a type 4, even though it is antiquated, i just like aircooled flat 4's cos they are simple and sound nice.
KruizinKombi ·
I think the idea is great. Wes may well be the first person in the world to drive a beetle with climate-control air-conditioning!!
speedster356 ·
Just do it Wes. Sounds pretty fine if you ask me. The Speedsters new engine is 1916 with Webers but just cos I like the sound and look....adequate HP but NOT CHEAP!!!!!
The Spyder has a Japanese Boxer engine with turbo.......more than adequate HP but CHEAP!!!!!!
The_Bronze. ·
"End of discussion"
Good. For the sake of civility lets hope he keeps his promise.
I'm keen to have a look. I'm happy with the Dog-O-War (71 Baja) as it is. It handles the beach ok I guess, Putts through the bush fine and turns a few heads. I guess the only thing more I could want is a fire extinguisher and a better paint job.
The Bronze. - As happy as a sow in feces.
jakriz ·
That is one of the coolest pics that I've ever seen.
Jak
Zenjoe ·
Im a little biased, but I would go with a mazda rotary. I got mine for $400 US from a wrecking yard and it puts out about 160hp with a weber 48IDA. It sounds really good and the competition will be blown away as you are blowin past them at 8500rpm! 😎
Doug Sweetman ·
I had a green 67 full bodied beetle, with 1600 single port for 3 years, then put 1800 type 4 in it, then crashed it and put a 57 baja body on it, with the type 4, then put the 1600 single port back in it (wa hey, 85kmh in a head wind MAXIMUM 🙂 ), then sold it, then I had a 78 kombi with a 4.4L v8 in it, and now I have nearly finished my 73 1303 with 1835 and twin IDF's. I ENJOYED ALL OF THEM !!
My point is - vw motors are cool (anyone here ever driven an oval with 36 of the best hp ?) in all their forms. VW's with conversions are great fun (the kombi really used to turn some heads), an excellent way to get power cheapishly. Each to their own.
Che Castro ·
hehe personally i dont like the sound of a rotary, but i like the sound of a Subie EJ20... nice. I would really like to be able to have a modern engine that doesn't overheat, drop valves require so much maintainence. its just that i would prefer having an antique flat 4 aircooled engine because i want to be able to say it has a vw engine in the back.
some people dont care whats pushing the car and thats fine for them 🙂
happycamper ·
The point i wan't to make is that if you think it is such a bad thing to put a non vw motor in any vw ,then you controdict yourself.My view is this,you cut the shit out of your vw to make it into a baja,you put non vw wheels an tyres on it ,maybe a fancy steering wheel,cd player.
As for end of discusion you would do all of us as well as wes a big favour if you just posted posative things not your biased opinion.
wes ,keep up the good work .
what a boring world it would be with out blokes like wes.
vdub2c ·
Heated topic ay...
Anyways, i've got a bug with a EA82 in it... it goes well and the turbo sounds like a treat when she flares up - then of course the wastegate kicks in and it sounds even better. The mods for the EA82 are minimal - cut a bit outta the fire wall and your set, it's not much wider that a bug's motor.
In regards to costs etc, an imported EA82 with computer, wires still attached etc will cost a little less than about $1200 which means if your budget was $2500, you could go for a bigger turbo 🙂 Plus the standard VW gearbox - I use an L Bug Box - can hold the EA82 power a lot better i'd say. I get 96kw at the wheels and it's enough to lift the front... do you really need more? 😉
an EJ20T ($1600 approx.) is alot bigger - which means more mods and space needs to be cutted out of the engine bay - my advice, buy the smaller engine - put an intercooler and a bigger turbo and your VW will fly anyways, for half the price and less hassles.
Baja Wes ·
vdub2c, I would love to see some more info and possibly pics of your car. I wouldn't have thought you'd lift the front on street tyres. My baja and my old L bug would spin the wheels and didn't have the traction to lift the front.
PS: fill out your profile when you get a chance.
vdub2c ·
Hey Wes,
Yeah they didn't for a while, then i put 9 inch rear wheels on the thing (welded two guards together to get one fat one 😉 ) i had ten inches for a while, but they stuck out too far and the RTA had a hissy fit. As long as it's not i the wet it lifts about a foot. only did it twice though, i'm over catious about the gearbox, i don't like dropping the clutch at all... plus when it lifts - i shit myself 😉
As for photos, my camera is rooted at the moment, but as soon as it's up i'll be sure to get photos on the site - I'm selling the bug if you're interested! 😉
Keep Cruzin'
Yianni 😎
shiftyvw ·
was your your bug red with big white wheels and used to get around in wollongong?
josak82 ·
Enough anger already
keep it friendly dudes.
keep it flat4
