hesitates at full throtle - SOLVED
https://forums.aussieveedubbers.com/threads/13008/hesitates-at-full-throtle-solved
breville ·
A new development increasingly worse
eg going up on ramp to freeway flat out building up speed then it starts to die as if im running out of petrol.
will run at idle - and after a while will go full throtle again.
im thinking fuel filter although i only replaced it last week - its night so i cant do a check right now.
if not filter then maybe fuel pump although it has only had about 10 months use from new.
any clues folks would be appreciated
vehicle is 72 S bug
Engine is a 1600 tp
Carbie is dual throat 40 dcnf
Petronics electronic points
New GT40 coil
thanks
[Edited on 6-9-2003 by breville]
[Edited on 8-9-2003 by breville]
Menangler ·
I would be checking the fuel pump pressure, if thats ok check the filter for dirt,
you may have got a gut load of dirty fuel?
breville ·
fuel pump hasgood presure when i first start watching it then it reduces to a pulsing dribble
would i be right - it need to be replaced (it is one of those non-servicable ones)
kombi_kid ·
try using some dual carbies if u have some
i think ur dual throat is probally leaning out!!
rhys
Fuel problems start at the tank clean it out and make sure the fuel line is clean and wrok to the rear replacing or cleaning as you go
Grey 57 ·
make sure the fuel tank vent is not blocked. As fuel is sucked out air must get back in. If the vent is blocked then the pump will not be able to suck fuel through for high demand like accelerating hard on the freeway.
Maybe why it goes good again after stopping for a bit. Vaccum in the tank subsides.
Peter Leonard ·
what dave said. there's a filter in the tank, which gets blocked by all sorts of shite that doesn't burn all that well. like leaves, twigs, hair, blue metal...
funny thing is, these things come straight outta the bowser. scary.
DO NOT REMOVE THIS FILTER!!!!!
theres only one way to fix fuel problems start at the front and work to the rear.
Good point Dean... I had a Vent problem a few years ago in my type 3... It was blocked completely and this make the problem even worse on a hot day.
Make sure the tank filter is clean and good,... I also use a small plastic throw away filter on the outlet side of fuel line before it goes into the pump.
breville ·
pulled out the tank and rinsed it several times - bad bowser i suspect - heaps of flakey black stuff
Cleaned the tank filter
Still no joy
cleaned the filter in the carbie where the fuel line goes in - lots of fine granules.
still no joy
replace inline filter
still no joy
Finally replaced the fuel pump.
yey team it goes again.
thanks every one
