How do u get pins out of old..
https://forums.aussieveedubbers.com/threads/13049/how-do-u-get-pins-out-of-old
jenz58 ·
OK, this is such an easy one but didn't want to stuff up or dmage my door handles
I'm wanting to take the trims off of Bels door to be reupholstered
I have to knock/tap pins out of door handles
Did try gently but worried about slipping and damaging something
What do u use to get them out and is there an angle your meant to go at etc?
My restoration manuals just say remove pins. OK? They didn't want to move, probably some spray first to loosen them
Easy. Just push/knock them out with a nail or bit of thick wire. Shouldn't need any more than a push with your hands (ie: you shouldn;y need a big hammer)
jenz58 ·
Will have another go tonight. I got no movement from them???:jesus
p.s. Thanks🙂
[Edited on 7-9-2003 by jenz58]
Adam_C ·
they took a bit of a hit in the beetle but should come out ok..... 1/2 hr before try soem machine oil in the hole ..... 1 drop should loosen it up....
good luck
adz
Jen I always get a friend to help as well to hold the trim back out of the way so u dont damage it when hitting the pin out with a proper size pin punch n hammer.
Much easier this way to have yr friend push the trim back around the handle so you can get at the pin properly.
jenz58 ·
Thanks Dave, I was worried about the plastic rim on the handles as I was trying it myself. Not worried about the old trim so much
Hmmm, proper size pin punch??? Is there one?
Adam_C ·
probly but not worth the $$ just use a nail hehe
jenz58 ·
LOL
Probably😉
If you use a nail.... thats when you break a nail....
Jen the plastic trims are available new from you know where. Now the trim is a lot more expensive thats why your trying to protect it.
jenz58 ·
But Dave trims are getting redone:sandrine
The whole reason to get them off, or has something gone over my head again?
No I don't want to damage the handles or the old plastic ring things on them:jesus😉
Really my main worry was stuffing the pin up
Hmmmm, this is kinda like pulling a tooth:o
Grey 57 ·
Nails the best option Jen. File down the point if you are worried about "nailing" something.
Just push the ring away with one hand , hold the nail in the other hand and hit the nail with the hammer. Easy!!!
Try not to loose the pins. Putting them back on is easy!!
Jen,
I tried to send you this info last night but it couldn't be sent for some unknown reason... something was down... server??
anyway I'll try again.
I have always used a pin punch to knock the pins out.
I tried to draw a pin punch for you but it didn't work after it was posted..
its approx 120mm long and one end (50mm) is 1/8th of an inch round and the other end is about 12mm round.
both ends are flat. the small end has to be smaller than the pin You are knocking out... they are available at most good tool shops etc.
its much easier if you have 3 hands Jen.
One to hold the Pin punch , one to hold the hammer and one to push the plastic ring in so you can hit the pin...
Best of Luck Jen...
I finally have a drawing so You can see roughly what it looks like....
__________
__________l=========
[Edited on 9-9-2003 by 68AutoBug]
jenz58 ·
The pins in the passenger door came out easily using a nail and just pushing gentle.
Seems like the drivers door trim hasn't been off in the whole of Bel's life maybe, the pins are really fixed in
It is awkward trying to hold the plastic ring and trim back and getting at the pins must admit, especially on the pins that don't want to budge
jenz58 ·
All of the panels are out except for the drivers door. Still can't budge the pins. Have soaked them, no movement
Is drilling them out an option?
from memory Jen, the pins are made from aluminium, so they are soft and easy to drill... check the pin you have out Jen... is it slightly tapered? if it is , they will push out easier one way.. have You tried pushing it out from both directions?
Normally they don't have to be tight as the plastic ring keeps them from falling out. It would akward to drill them out.
best of luck.. Lee
You probably need something stronger than a nail (mild steel) to move the frozen pin.
Do You have a small screwdriver or something hard You can really hit the end of the pin to dislodge it... Once it has been moved (unfrozen) then use a nail to push it completely out..
I hope this is of some help..
A pin punch would do the job easily. Lee
jenz58 ·
I've been hammering at the pins from both directions:cussing
Thought it might loosen them or one way may happen easier etc:jesus
oval TOFU ·
try a punch- its like a screw driver in that it has a plastic handle and all, but the tip is a point rather than a flathead or phillips driver... Obviously get one thats about the same diameter as the pins you are trying to drive out.... a bit of WD40 probably wouldn't hurt either..
:thumb
jenz58 ·
Soaked it in WD 40 but will go get a punch drive thingy:thumb
Well they are the words I will probably use if I have to ask:jesus
Jen
take one of the pins You have taken out so the tool people will know what size You need. its called a Pin Punch and its All steel - no plastic handle - and it shouldn't be all that expensive....
Best of luck..
Jen, if I lived close by I'd do it for You...
regards Lee
_______
l_______l======== Pin Punch
jenz58 ·
Wow, 19 replies for getting two little pins out
It's a bit like micro surgery maybe:o
Thanks Lee. I hope I don't loose the bl14dy pin if I take it somewhere cos I've got it nice and safe right now. Tiny little buggers😉
P.S. PIN PUCH WORKED WITH A LOT OF HARD HITTING
why am i yelling
All trims are off:thumb
[Edited on 18-9-2003 by jenz58]
