I want to pull it off to recondition the whole thing. Two questions:
1) What would need replacing apart from the L&K pins?
2) the dickhead of a PO welded one side of the beam to the frame because the bolts were rusty. Are the original bolts welded to the frame or go straight through it? I mean once I cut the non original welds to get the beam off. Do I have to take the car to someone to weld bolts on or I just stick the bolts from one side of the frame through to the other side and bolt the beam to it?
Actually one more question, is it worth putting adjusters on it while I am at it? I would like to lower the car slightly but not on the ride quality expense
Raf
karmannghia60 ·
