Tnate wrote:1600 AD model engines are out of a early 70s kombi.
The timing on the engine with a 34 PICT 4 carb is 7.5 degrees before TDC.
Statically, it is the notch on the pully on the right.
Tnate
I don't know about the AD series engine being used in Kombis etc - but 990,000 of them were used in beetles from 71 to 73 inclusive. (see the full list of engine numbers at
http://www.geocities.com/aussiebug1970/years.html )
You're right about the timing Tnate, but not completely right. The actual timing for a VW engine depends mostly on the distributor being used, NOT on the carby being used.
If the engine has a single vacuum distributor (either vacuum-only or SVDA -single vacuum double advance), then yes - 7.5BTDC is correct.
But if it has a 009, it has to be timed at 28-32BTDC at 3000rpm, and let the idle fall where it may (usually between 5 and 10BTDC). 009s vary in how much total advance they make, and max advance is more important than idle advance, so the max advance has to be set first with these distributors.
In the USA may of the AD series engines had a DVDA (double vacuum double advance) distributor and these had to be set at 5ATDC (that's AFTER TDC) at idle with both vacuum hoses connected. This was an emissions thing, and it's just possible a few of these distributors found there way to Aus. The retard vacuum hose pulled in the retarded ignition at idle, but the advance vacuum line started working as the rpm rose off idle, so the timing then jumped to 7.5BTDC and then started advancing normally from there.
