Mike Sharp of Sharp Built in Toowoomba QLD
http://www.sharpbuilt.com.au
sells adaptor plates to mate Subaru motors to VW transaxles. He will also have available by Xmas a shortened alloy sump. The sump is 3 inches (75mm) shorter than stock and carries the same oil capacity as stock. I read somewhere that you shouldn't shorten the sump more than about 2 陆 inches as you will end up with oil frothing problems. I will try and find out where that came from, as this may have also been in relation to a reduced oil capacity. I don't know how much shorter the KEP sump is, but it does maintain the original capacity. Any way, see Mike's comments below:
"To modify a stock sump like KEP do it will cost about $250-$300
This is why:
A new steel 'sump box' has to be made and welded up, holes are then
cut to let the oil sucker tube go through and extra hole's made to let the
oil fall into the sump, and the dip stick tube has to be repositioned.
The donor sump then has to have the baffle plate removed and then the
sump is cut to the new level and the new 'sump box' welded on
I can make a brand new alloy sump for about the same price as a welded
one and there is no exchange required, that's why I am making one for my
EJ 2.5 engine going into my new dune buggy, It will also look much nicer
than a welded up sump.
Regards Mike Sharp"
[Edited on 14-10-2003 by Jenny]
