Iam am having some problems with my brakes. I bled them and adjusted them, wasn't happy had a vw shop so it, and am still not happy.
U use alot of force and the car just doesn't pull up, but add a little bit more, and they will lock up.
so what could be causing it?
I do run heavier front springs and the tyres are warn.
Also what is a good brand of performance brake pad for an L bug?
thnaks BiX
Ray65432 ·
Disconnect and block off vac line to booster and carefully drive it and see how it performs.
It sounds to me as if your booster needs reconditioning.
MickH ·
Booster???:jesus
Jenny ·
Hmm, I don't think my beetle has a brake booster either. Did this get added to the L bug?
mnsKmobi ·
If you have front discs you may have the same problem I had on my 74 Honda Civic. The "slides" were seized. The brake calipers worked by having one pad driven directly by a piston and the other pad moving on a couple of metal rods (the slides). Over time these slides gummed up with brake dust and stopped working. This meant that only one disc pad on each disc was getting the full brake force.
Baja Wes ·
L bugs certainly don't have brake boosters. Only kombi's get those.
Any chance you've got oil or grease on the pads? if so they will need to be replaced.
Do the brakes pull to one side at all?
Do they remain on at all?
11CAB ·
Beetles do not have brake boosters, and do not have caliper slides......Jack the car in the air and have someone spin the wheels while you apply the brakes to make sure each wheel is braking. The pistons could be seized, the flexible brake hose could have a flap inside that can collapse causing problems, the rear adjusters could also be seized .
See how you go.
MickH ·
Have just fixed my cousins car (beetle) that had the same problem. Found one front brake hose to be badly deteriorated and the caliper pistons were partially siezed in the bore. Had a spare set of callipers which had recently been reconditioned from a "donor"so just put them on and replaced both front brake hoses and pads. The discs were badly worn so we replaced them with the ones from the other beetle. Test drove and now working well. Would reccomend you check your callipers first!!:bouncegood luck.
