hi there,
something a bit nuts is going through my mind for my oval...a rotary conversion, as anyone done so, what needs to be done...all i want is to put the the engine in,still carby like a 12a..maybe turbo...don't want all the trouble of fuel injection..any comments would be much appreciated...also what gearbox to run?
Baja Wes ·
Legally you will only get away with a naturally aspirated 12A, and only if you can prove your car weighs over 800kg. They multiply the rotary capacity by 2 to get an equivalent capacity for the legal side of things.
rotary yes!!!!!!!!!!!
forget these haters sleeper if you need any info let me know ill do my best to help. im also looking into this at the moment for my notch.
Stanley ·
:puke:puke:puke:puke:puke
13Beetle ·
Hi There, I've just started a 13B Turbo conversion, I'm going to run the motor on straight gas to bypass the fuel injection etc. I've mounted the radiator in the spare wheel well, and am currently looking into the most convinient way of transfering the coolent from front to back. Any ideas ?? If you need any info please get in touch.
lowdown ·
kafer69- we get the point! you dont like rotaries, obviously sleeper does. you saw the title of this thread so next time when you see rotories in a thread title do us all a favour and dont open it and keep your closeminded views to yourself!
13Beetle ·
Here Here lowdown, well said !!!!!
As Wes said there is factory weight to consider with all conversions. Check with your rego people. A 12A is 2.4 litre, so your car must have weighed over 800 kgs from the factory eg 3 x 800 kgs = 2400cc maximum, a turbo 13b would need your bug to weigh 1040kg from the factory, not likely.
As far as getting the water to the front of the car, I used 1.5 inch stainless tubes running under the chassis near the heater channel bolts.
1302Steve
13Beetle ·
The car needs an engineers report, Brake fade test, lane change manover etc. I've located an acredited engineer in Ballarat who is happy to help me gain rego for the car. I've heard and read of some people running flexible truck heater pipes through their heater channels, do you think this could work??
I think the idea of a rotary in beetle is a good idea. I know some guys who are into rotarys and some that are into veedubs and they both have something in common.
That is the Commodore boys all look down at them generally.
Dare to be somewhat different I say.
I get a real black and white response in the bus. Some people out of the blue at the traffic lights will wind down the window and say 'cool man' others will say 'why do up a kombi?' or similar.
I enjoy the attention good or bad. 😀
Herbie ·
Go the rotor option, no problem at all.
I'll help you,
I cant see the difference between puting a rotary engine into a bug VS removing the body and replacing it with a buggy and getting out on the sand,
Except one is easilly reversed.
VW owns NSU, and NSU owns the rights to the rotary engine design so its really not a blasphemous option.
If I had the adapter kitt funds right now, the rotary engine in my garage would be bolted in quick smart.
I find it frustrating that I need to ring Herbies neck just to merge into traffic.
130 reliable horsepower sounds good to me!
I know it not legal but a turbo rotary sounds awesome to me too,
Take a look at this. Rotary in a beetle video
13Beetle, you should do some checking before go much further with your project, Im sure that you will find that you must conform to the same rules as we do in NSW, or you will have to in the very near future.
1302Steve
13Beetle,
any chance of some photos of how You put the Radiator in the wheel well and ducted the air thru.... Lee
Stanley ·
lowdown wrote:kafer69- we get the point! you dont like rotaries, obviously sleeper does. you saw the title of this thread so next time when you see rotories in a thread title do us all a favour and dont open it and keep your closeminded views to yourself!
Ok ok point taken my apolagies to anyone I upset but yes I'm not a fan of rotaries in or out of VW's however my hat goes off to Mazda for thinking outside the square when it comes to engine development.
Just let me say in defence i'm not narrow minded if i was to walk past your car and it had a rotary conversion and it was engineered real nice I would appreciate the work you've put in however if it looked like everyone elses i'd probably keep walking.
Take Wes's baja, hats off to him for his conversion he's done a fantastic job and it doesn't just go quick it looks good to. At the end of the day if all you want to do is go fast relatively cheap go a rotary.
Brad ·
And I was just about to point out your non standard bug avatar 😀:P:P
13Beetle ·
1302Steve, love your bug, I think the main problem that I'll come accross is passing the brake fade test. The engineer is recomending a brake upgrade. I've spoken to a few poeple and they reckon 1975 porche 911 front disk (ventilated) will bolt on up front with a little machining and go for type 3 drums on the back. What do you think??????
sleeper ·
well thanks all for the replies... i didn't suspect to see so many people interested in the rotary conversion...as well as people not interested 🙂 ... anyway....
herbie, let me know when you put yours in i'd love to see ti for sure..
13b ... good luck with the engineering...keep us updated.
cheers.
Baja Wes ·
I can tell you the 13B isn't legal in QLD or NSW in a bug.
Vic is different, but as Steve pointed out it won't be for long.
13Beetle ·
It sounds like I need to get moving with the project. Body and pan are seperate at the moment, sandblasted, and primered. I'm about to start the IRS conversion then I can start painting and putting it back together. Cheers for the comments.
fuz ·
thats a great idea putting a disposable engine in a classic car....
why must you bastardise it with maztech parts when you have perfectly good choice of other brands to bastardise the oval with
do it but expect to do it again in 2 years
13Beetle ·
I look at it this way fuz, If there is another vee dub on the road then that is great. If someone wants to try something different (eg water cooled engines) In their vw's then we should support this. At the end of the day it's cheep horsepower that you could have alot of fun with. 13Beetle !! 😉
i will start with i know crap about conversions
BUT
I thought i had read that the rotary was a high weighted motor and made the bug a bit twitchy in handling???
Comments???
Barry, Richard from VForce had a friend who used to club race a rotary bug, when he went back to an AC motor he found the car handled much better.
1302Steve
Herbie ·
My Father always taught me that it was better to say nothing and be thought DUMB,
Than to open your mouth foolishly and remove all doubt.
If we were standing in a line at the bank, do you think you would present such a narrowminded, arrogant, missinformed yet fearlessly vocal persona?
I doubt it.
So why act like a dick here?
Would you like to come give us driving and sexual techniqe insults too.
You display a pityful knowledge of rotary engines, engineering and social skills.
Doug Sweetman ·
Fuz - if the rotaries are so shit and only last two years, why is it that so many of the series 1 rx-7's still have original 12A's after 20 odd years ?
Wankels are the same as vw's as holdens, ford, ferrari and any other engine you can think of - look after them right, and they will last a shitload longer than if you cane them to death and dont look after oil etc.
Talk facts not opinions.
ByronBug ·
:sandrine
Like I mentioned before in another thread & will do again in this one...
To each his own...
I don't care what you do to you VW as long as its on the road & looking kool.
If you want to do anything to your car...it should be appreciated for the desire to think outside the square...
If it wasn't for people like this, where would we be in motoring & technology.
Its these people who take the itinitive to discover what can & can't be done to engines & discovers new technology for us to see & try
If you don't like something...thats fine, you are intitled to your opinion, but be mindful & considerate, & remember there are others here with different opinions.
Respect all,
Judy
lowdown ·
nice one herbie, i always wonder would these people say these things to my face if they were standing in front of me???? somehow i doubt it.
fuz ·
OK.. so i my opinions differ from that of your own but they are exactly that my opinions.. i just think that twin rotar engines while are cheap $ - HP they are not what i would want to put into an oval.. so yes i spurt off some unwaranted crap at times but its my opinion.. besides the last rx7 that used to cruise with my group of friends fried.. so based on MY experiences i would not reccommend one, HOWEVER as i said these are my opinions and i am glad that your opinions differ cos.. how boring would life be if we all thought the same thing..
and to close this sad rebuttle .. stop pickin on me im only little :P
Baja Wes ·
Having your own opinion is one thing, but being rude about it is another.
Your first post was clearly in the rude bracket, even if you were trying to be sarcastic.
Just watch the way you word your opinion, or expect a grilling. :thumb
Hmm
Yep must be nice or someone will grab you by the short & curlies
1302Steve
Stanley ·
fuz wrote:besides the last rx7 that used to cruise with my group of friends fried.. so based on MY experiences i would not reccommend one
Well....everyone knows my views on the rotary engine, however thats got to be the most narrow minded reason not to own one.
where would this forum be to-day if the designers of the first horizontally opposed aircooled engine took that view.
and yes lowdown anything I say on this forum i would say to someones face.
Long live well engineered VW's with any powerplant even if it has to be a rotary.
Hey FUZZ can you advise us all what is it that you race....
Are you into Drag, Dirt, Circuit or hill climb ???
fuz ·
canetoad
fuz ·
and about the first post i really did not mean to offend... im just not a fan of rotaries.. nevermind, i guess some things just dont translate into text how you want them to
Herbie ·
Sorry to chop your hand off just because you were pointing.
It is hard to get the inflection included in your text and easy to offend,
No Damage,
If/when I do a conversion on Herbie I'll take you for a spin,
Cheers Tony.
fuz ·
sounds like a blast! nothing better than a long ride in a quick car 😀
