what can i do about the gapping hole in the front grill on my 65 crew. does any make the cover that fits over the hole or is there a great welder/fabricator out there who can rectify the problem or should i fill it with a stereo/cd player???
Bizarre 路
bog or gaff tape
both look quite nice if done with artistic flair 馃榾
lobus 路
I would go the stereo route or maybe use the hole to fit some gauges. You could also use it to hold your man bag. There are many good uses for a hole. Anyone else got any ideas?
twoguns 路
there is a plate option that you can get that covers the hole where the radio fitted. i have a plate in mine. you do see 'em around.
Peter Leonard 路
few have the artistic flair that blue has with bog and gaffa, i'd go the hinged checkerplate front, hiding the place where you keep your manbag. 馃榾
byronbus 路
I have a cover on mine
frog 路
Have seen some shocking axe attack jobs on split dash radio areas but all you need is a doner dash,cut out the bit you need neaty with a panel saw,cut the same bit in yours and weld it in and grind smooth,you will have a good as new radio hole and I think it is the only serious way for it to be done.The good thing is a split dash is always in perfect nick even when the rest of the bus is shot .
AndyL 路
so i need a donor dash and bruce who keeps his covered can come over and help,thanks guys. are the cover plates a nos item or are they non existent?
pyr0 路
hey twoguns can you post a pic of this thingy your talkin about ??
