Do you just pack it with grease when installling it and that will last it for its life time?
Raf
karmannghia60 ·
https://forums.aussieveedubbers.com/threads/13692/where-does-the-clutch-thrust-bearing-get-its-lubrication-from
karmannghia60 ·
karmannghia60 ·
Baja Wes ·
oval TOFU ·
karmannghia60 ·
*did* ·
I have the same problem. I havent checked the oil level in my gb yet, that may be the problem, if so i will top it up. I will let you know of the results when i get around to it.oval TOFU wrote:I've got a split case GB and it makes more noise when i have the clutch pedal up... ie: the gears are turing (even in neutral). When i press in the clutch, the noise goes away.. so its oppostie to a worn thrust bearing!
Grey 57 ·
