Just stripping down a recently acquired type 4 1800. It was quite full of sand and a bit siezed so figured it would be nice to pull it apart....
Just wondering what should I keep ???? are things like the push rod tubes, push rods interchangeable ? The heads dont look too bad at first glance no cracks etc. should i just hang on to the block for spares if and when i need them ?
Any advice mucho appreciated.
Scooter
Andy 路
EVERYTHING DUDE!!!!
Never know when the worthless part will become NLA and you need to use an old one.
Noth that I'm a hoarder or anything 馃榾馃榾
scooter 路
the misses is gonna go nuts ill have to stash it in the shed 馃檪 I suppose I better keep it in case you need some bits...... :o
S.
helbus 路
I would say keep your wits, keep your sanity, keep your desire etc. 馃榾
modulus 路
What they said, plus...
Keep the heads; the 1800 heads have bigger valves than the 2000 and are interchangeable, thus are pretty popular.
hth
Phil74Camper 路
Pulling down a Type 4 motor is great fun if you've only ever done Beetle engines before. You'll be amazed how much bigger and stronger everything is.
I'd strip everything down to the last nut and bolt, and clean everything thoroughly to get rid of any sand. See what's ruined and keep the rest!
Nearly all Type 4 parts interchange between 1700, 1800 and 2000 sizes. The pushrods, tubes and rockers are all the same. The heads are different; 1800s have the biggest valves but they all fit. The only difference is the crank on 2000 engines - they have 50mm big-end journals. 1700 and 1800s have 55mm. You need the matching crank-rod set.
Type 4 parts do not interchange with Type 1 though, if that's what you're wondering!
KruizinKombi 路
Keep the whole lot complete until you need to dismantle it. They tend to keep better that way, especially if you keep oil in it and give the crank a turn every so often. 馃檪
