Noisy gear stick.
https://forums.aussieveedubbers.com/threads/13765/noisy-gear-stick
bojac ·
Hi all,
my '76 beetle has got a noisy gear stick, it sort of vibrates at certain speeds.
Is there a cure for this problem?
Thanks for any help.
Jack.
Oasis ·
Something on this thread might help.... http://aussieveedubbers.com/forum/viewthread.php?tid=13503
Good luck
Almost 99% the little clip on the shift rod
Also change the coupling at the back as well
As Oasis said it is covered in the other post.
Best description i have read is the one on SuperbeetlesOnly
Tis only slightly different for a standard and a super.
The standard has the little cover hole in the front apron. Painful fiddly job but easy (ish)
[Edited on 25-9-2003 by blue74l]
bojac ·
Thanks a lot for the info, I do appreciate that greatly.
Jack.
