These are 2 sites woth reading on how to jet your carbs
http://www.redlineweber.com/html/Tech/Table_of_contents.htm
http://www.aircooled.net/gnrlsite/resource/articles.htm
I have scanned some pages on DNCF's but it is at work and i am away for 2 weeks. Try Helterskelter or Cray. I believe they both have the pages
As for jetting sizes
Idles - what ever the motor wants. 95% of cases it is a 50 - 55 idle. That said my IDF's want a 40
馃槈 Read those articles and you will see that there is a sweet spot on the mixture screws. THIS ALONE determines you idles
Mains should be 4.1ish X venturis size. If you have 32mm vents then a 130ish jet is a good starting point
Airs shoud be 50+ your mains.
So in my case it is 40 / 130 / 180. This is with a F11 Emulsion tube
Your vents are determined by your valve size. They say 3mm small than you inlet or say your exhaust valve.
28mm vents are too small for anything. A stock valved head (35/32) should have at least 32.
A big valved 40/35 should be at least 34 or 36
Where to buy?
Well dunno about Tas but most go fast shops sell jets. A company called Carburettor Service @ Burwood Sydney does mail order. Cant find the # at the moment
[Edited on 30-9-2003 by blue74l]
