Flywheel changeover
https://forums.aussieveedubbers.com/threads/14010/flywheel-changeover
Adam_C ·
Can someone out line what exactly is dont to change a flywheel from one moto to another . . . . and how to use a peice of angle iron as a flywheel lock,
thanks
adz
Drill two holes that align in the clutch bolt hole so u bolt the angle iron to the flywheel and it locks against the ground
Ive been doing it this way since 1969 or so,
Adam_C ·
ahhh . . . . . i has it on the clutch plate bolt and the bellhousing stud . . . nowonder it was really weak and didnt like the pressure......thanks dave 🙂 ur a champ
adz
Adz
Ive had the piece of angle 50 x 50 x 1 meter long for years n years... I have different holes drilled in it for various removal procedures on most type of VW engines.
I would be lost with out it, go get yourself a length and you will find it most usefull over the years while yr playing with cars ...
Adam_C ·
yeh dave got a bit here . . . .just didnt wana do it wrong and snap the stud
ill let ya know how i went
ads
