anyone ever had a single weber setup on a bay kombi? if so what was it and did it work. ie: enough power
Robo ·
How are ya man
I have a single proggressive on my 2ltr, It hates the cold, the long runners of the manifold get cold and the fuel condenses in them, it also has a bit of a flat spot just off idle, apart from these things it runs well, there are a couple of things you can do to solve the icing problem.
Feed the air intake warm air, and run heating wires on the manifold tubes.
I have had the webber on for a year or more and haven't had to touch it tuning wise, just set and forget. It dose give you a slight increase in torque (middle range)
I will leave it on untill I can afford a set of dual 40- 44 dellorto's.
Rob.......
nuffy ·
thanks for the reply.
what model are the ones you are using.
