Is the EA81 and th EA82 conversion, adaptor plate the same!!!
matt
wacked1 ·
where did you get the adaptor from. or you can call Bill Croft unicap or
john Shermin a call to confirm.
UNICAP ENGINEERING PTY.LTD
Head Office:
34 SPINKS ROAD
LLANDILO
NSW 2747
AUSTRALIA PHONE: +61 02 47 774006
FAX: +61 02 47 774830
TELEX: UNICAP AA 20013
wacked1
:jesus
baybuscamperkid ·
NO, as far as i know they are completely different engines. the 81 is basically the same engine as the 71 with a different stroke, the 82 came later, same capacity as the 81 but as far as i know a rather different engine. i know for certain that fitting it is different, different engine mounts etc, so i presume that the adaptor plate may also be different.
Anthiron ·
the EA82 engine came in with the more modern and squarer shape in the L series subarus it is a very different engine from an EA81 and having driven both i would say that the EA82 is superior.......my subaru leone turbo has an 82.......if i was doing a conversion i would be using an EA82T ....as for mod plates i would suggest that no they arent the same
humpty ·
You must remeber that these engines are getting VERY long in the tooth......They are nearly 20 years old for pete's sake! B4 you commit to this conversion, maybe look into a newer model such as the EJ20/22/25. Cheap, plentiful, more power and much better technology. There are loads of Brumby & Leone owners here in Perth that are stickin' EJ20T in the front, Cheaper than a rebuild so they tell me!
