hey
whats the difference if there is any in a 2L and 1.8L gearbox bellhousing??
rhys
REDKG ·
the engine case is the same so should the bellhousing
amazer ·
No the bellhousings are longer, input shaft longer, starters are different to clear the bigger clutch.
Bolt patterns are the same and they are interchangable.
A 2 litre also has longer studs on the bottom of the case.
[Edited on 5-10-2003 by amazer]
kombi_kid ·
hey
so if i have a flywheel cut to an 1800 size flywheel it should be alright???
rhys
amazer ·
What exactly is the combination you want to use?
Its the pressure plate which causes the problem. The 2 litre is a bit bigger. Ring gears are the same. An 1800 clutch/flywheel will work in a 2 litre bellhousing with 2 litre starter. Vice versa doesnt work. The flywheels are a direct swap over but I guess VW must have assumed the smaller clutch not up to the task of the 2 litre. It would probably be OK if not fully loaded and/or abused. I actually used an 1800 clutch and flywheel when trying to get my kombi home from newcastle. It was towing my empty car trailer and didnt appear to be slipping.
kombi_kid ·
ok this is what im gonna use:
i have a V6 which im fitting the flywheel was cut for an 1800 gearbox and as was the adaptor!!
so does it matter if i use the longer input shaft of the 2L box into the 1800 flywheel and clutch/pressure plate???
rhys
