Clutch shudder problem
https://forums.aussieveedubbers.com/threads/14363/clutch-shudder-problem
duncombemu ·
I've just changed from a 1200 to a 1500 in my '62 IRS Beetle. Now when I let the clutch out, like I've always done and now I get violent clutch shudder. Please can someone let me know how to fix this.
Regards,
Mark :thumb
56astro ·
The first thing I'd check is that the boudon (sp) tube has the correct amount of bend in it. About 45mm I think the manual says.
After that, no idea sorry.
Yes check the Bowden tube, also the steel tube coming from the chassis tunnel, sometimes the welding breaks away from the steel tubing, especially if the chassis was from a Semi Auto beetle..
The other two things: Your clutch is out of alignment? or Your clutch cable is frayed and starting to break strand by strand and stretch at the same time.....
and will need to be renewed... before it snaps completely...
Did you check the clutch and pressure plate on the new engine.
If you change the gearbox did you chack the chutch throw out arm for cracks and see if its square.
could be a number of things
Is the clutch adjust correctly and is the outter tube fitted right
wadd ·
ya gota admit that engine sures is brrright,sort of make ya wonder what colour ya paint the car :vader
duncombemu ·
Yes, I do understand all these things that can contribute to the shudder problem. But I was driving the car for a while that the engine came out of, without any problems. The car that the engine is in now never had any shudder problems either. So the only thing it can be is what 68AutoBug has said, that the clutch is not aligned properly. The Bowden tube hasn't been touched, so that should be OK. So do I have to remove the engine again to align the clutch?
Thanks for the ideas, guys.
Regards,
Mark
speedster356 ·
My gearbox mounts failed and it always shuddered on takeoff.
The clutch outer may be wrong as you have fitted a new engine and it will have different distance to the pressure plate so please check that its not too tight ofr loose first.
Thats another one I forgot... engine/gearbox mounts... when worn out these move as You let the clutch out and can make the cllutch shudder...
these should be replaced when You have the engine out.... or a clutch replaced...
for some reason - there is a difference between the original engine & clutch and this engine & clutch... & the flywheel..
Maybe the clutch bearing has reached its limit of wear... but... it certainly looks like an engine out job.....
duncombemu ·
I'm sorry Dave, I've looked in the book for 'clutch outer' and can't find what you mean. Please enlighten me with this procedure.
Mark
the clutch cable outer sleeve runs between the chassis and the gearbox.
it has to have a certain amount of pre tension or bend in it. the clutch cable runs through it to the clutch lever arm.
its called the Bowden tube as well.
