Aussieveedubbers 路 Tech Talk
Balancing dual carbies on a type 3?
https://forums.aussieveedubbers.com/threads/14406/balancing-dual-carbies-on-a-type-3
jenz58 路
OK
I think my carbies need to be balanced.
The type 3 service manual I have doesn't seem to have it (would they call it something else?) Couldn't even see a pic of anything that looked like a carbie馃檨
Went through the indexes as well at beginning of each section
I figure it's something I should learn to do馃檪
I'm off to help Jay paint her back room so she can get back online. If I don't reply real soon you'll know why:thumb
Bizarre 路
http://www.aircooled.net/gnrlsite/resource/articles/dualcarb.htm
Jen
read the above story.
I will qualify first by saying i dont know if Type 3's have a single idle circuit set up like on my kombi. There you only adjust the right carb. You dont balane that style.
Unless you are experienced ehough to do it by ear you need a synchrometer
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=TZE0021&cartid=1011200319834864
only buy the one on the left
PurpleT3 路
Hey Jen,
T3's have a dual idle circuit, ie you have to adjust each carb separately. You will need a synchrometer, as stated by Blue, and a tach/dwell meter. Muir's Idiot Guide also has a full Procedure for balancing.
68AutoBug 路
I used to do it just with a tachometer...
fairly easy...
PurpleT3 路
Lee,
care to expand, would save me buying a synchrometer.
1303Steve 路
You need to 1st do the usual tune up, get the mixture close as you can, then balance the carbs at idle, disconnect the linkage on 1 carb, pull the spark plug lead of #2 & #4 one at a time to see which side is idling highest, get them to drop the idle on each turn so that the motor souds similar after removing each lead, recheck mixture and reset balance, nearly finished, now you need to make sure each carb opens at the same time (syncronise), and keep blipping the carbs as you balance them to make sure they sitting back on the idle stops. Lees tacho method can be used to get a better idea of the drop in revs side 2 side.
1302Steve
jenz58 路
Thanks guys, will go get my idiots guide out now and have a read馃槑
In my type 3 service manual would they be calling the carbies something else?
Jay's room isn't finished but we had a good chat while we painted. Then we both got dizzy from looking up and painting the roof and top part of walls ,so stopped once that was done. She'll be off line a bit longer馃檨
jenz58 路
Hmmm, after reading my manuals I'm thinking my valves need adjusting
Not due for a service (still another 900 mls to go) but think a tune-up is needed
The Dr is running well but is having trouble getting up a very steep hill near me when he isn't fully warmed up. He usually doesn't have a problem with it
Any thoughts?
