Flywheel Woes--- i tighten and it stops spinning
https://forums.aussieveedubbers.com/threads/14502/flywheel-woes-i-tighten-and-it-stops-spinning
Adam_C ·
hey, as i tighten the flywheel going onto the 1500 it becomes extremely hard to turn over, and when it becomes tighter i cant push it (flywheel ) into the case (this thats endplay???)
ive taken one shim out of the hole there the seal is, what is happening??
modulus ·
Have you seen this thread?
http://www.aussieveedubbers.com/forum/viewthread.php?tid=13546
hth
Adam
fit the flywheel to the crank with NO shims or Seals and measure the distance it mooves back n forward.
push the crank one way and measure from the outer face of the flywheel to the crankcase then push the crank the opisiteway and measure. this will give you a figure less 0.004" from that then divide the measurement by 3 and thats the size of thickness of the shims required
If its locking upo then something is WRONG dont go any futher.
Adam_C ·
is there different size shims or is it just the amount that i put in there?
adz
yes there are about 6 different thickness available.
You have to make up the difference with a quantity of three shims. This is to stop binding.
Make sure you tighten the wheel on first with no shims or seals in place.
Adam_C ·
how is the rear seal removed, the Large end seal
sorry bout all the Q's
adz
Use a flat blade screwdriver and lever it out trying not to damage the soft case. You can pivot of the end of the crankshaft.
Adam_C ·
thanks for your help guys, worked it out today.... .23mm shims what i need and .24 is available so im set 🙂
will order them and have the engine goin in no time
adz
