stainless braided fuelline
https://forums.aussieveedubbers.com/threads/14526/stainless-braided-fuelline
robnjo ·
whats the deal with this stuff.I put it on no longer than 4 months ago and its splitting at the ends under utilux clamp just above dissy!!! :cussing Has anybody had this prblem too?
[Edited on 15-10-2003 by robnjo]
robnjo ·
does anybody use this stuff???
:alien
speedster356 ·
I used s/s braided fuel/oil lines with the engine upgrade but I used the aluminium fittings with no problems.
robnjo ·
thanks,I'll see how I go:thumb
555bug ·
just make sure that when you cut it that you put some masking tape over the cut line, then use a fine hi-speed cutter ( i use a Dremel at 20~30000rpm) and there should be little fraying etc.. If you do it right it will be cool forever.
robnjo ·
its just the rubber is splitting around radius of the hose (splits in directionof fuel flow)🙁
