generators pulleys
https://forums.aussieveedubbers.com/threads/14602/generators-pulleys
Midlife crisis ·
can anyone tell me how to make sure the pulleys line up when replacing the generator
thanks
marc
It just lines up
When you put the front half on (front is front) it has a key way to lock it in place. Its a bitch trying to slide the pulley on and not slide the key out the back but it can be done.
Then the back one goes on where the tangs line up or the round/square hole over the shaft
Midlife crisis ·
Sorry I did not explain I meant when you are putting the genny back on the engine and line it up with the fan pulley so the fan belt is straight
thanks
Marc
ok see if i understand
When the shroud goes back on it will sit the genny/alt in its cradle and again it has to line up.
The only way it cant is if the shroud isnt sitting in the cylinder covers properly
Then its not a genny problem but a tin problem
Once it is all together a piece of wood/rod/steel and a good eye will tell you if its lined up.
never had a problem putiing then back and finding it out of alignment
Midlife crisis ·
ok will check thanks Blue
marc
