Type 3 brakes?
https://forums.aussieveedubbers.com/threads/14633/type-3-brakes
crazyfiggi ·
I have type 3 brakes front and rear that i am going to fit to my bug. Will these bolt straight on?
Thanks,
Alex.
matara ·
Are these early or late Type 3 brakes? What year bug are you fitting them to? I'm pretty sure the rears a a bolt on fit
Tazz ·
Rears do.......Early or late... Just change the backing plates too.
Fronts...
Hmmmm....
dunno..... should do...
Tazz
crazyfiggi ·
Sorry, they are 4 stud pattern and will be fitted to a ball joint/irs bug.
Menangler ·
Rears bolt on if it is an IRS or wide swing axel gearbox ('68 and later), if its an early beetle you will need to machine a bit off the drum where the 36mm nut goes, 12mm I think?.
The type 3 early drum fronts don't fit Beetles.
crazyfiggi ·
Will the type 3 front disks bolt straight on?
Thanks,
Alex.
11CAB ·
Apparently there were two types of type 3 calipers....I think there were a changeover model the had the same bolt spacing as the beetle and could be bolted straight on but the other ones have the bolt spaces too far apart.
The 71 & earlier calipers & rotors will fit a bug. The later ones have wider spaced bolts.
These are the 2 different pad types.
1302Steve
Depends if you have short or long rear axles. Depends if you have one or two piece rears as well.
crazyfiggi ·
I think mine are the later model calipers, can they be made to fit a bug? would it be posible to use the type 3 spindles on a bug front beam?
Thanks,
Alex.
