They wont fit a 4 stud bug, Im pretty sure that they are 4 x 100 mm. But if you wanted to fit the 924 drums & discs to your car they would fit.
1302Steve
Unity-28 ·
You might want to check, cause 914's Had the same 130pcd as Late VW! If they do they would be a pleasant change from all the regular wheels that fit onto stock brakes! 924 basically ran with VW suspension including Trailing arms and struts! Dont see why they would have changed the brakes either (stud pattern is what I mean!)
N!
They are definatly not 4x130, just cant remember what the pcd is, I have seen them on Audis.
1302Steve
karmannghia60 ·
They won't fit a Beetle but will fit on a Golf/Passat (with spacer on the front)
The 924 drums & rotors can be fitted to 4 stud bug, opens up a whole new world of alternative wheels.
1302Steve
VWFOOL ·
thanks guys
i looked a bit more into it, i think the pcd is like 4 x 108 or 110 something like that.
now, im wondering wat would be involved in changing the breakes over. r the rears discs on 924 4 stud? i hav no idea wat u would need to do, can anyone help?
thanks
sam
It looks fairly simple until You see the rear disc brakes...
Makes it a whole new ball game...
a hard one at that..
But Nothing is Impossible....
Just a bit Harder.... Lee
VWFOOL ·
so wats the answer, how do i go about it?
wopuld it be easier to hav rear drums redrilled to 924 and replace the fronts with actual porsche discs?
The 924 had rear drums, they are the same as 4 stud beetle apart from the stud pattern, same deal with the front rotors.
