Question - USB connection on puter???
https://forums.aussieveedubbers.com/threads/15387/question-usb-connection-on-puter
jenz58 路
OK I know there are enough puter nerds on here to answer this one, and at this hour!!!馃槈:bounce:bounce
Not that Tandy or anyone else is open now for me to run out to!!馃檨
Can you buy adaptors for the ends of USB going into the puter
I have 2 spare ports but connection is wrong size!!!馃檨
I have my cable for the video in one OK but just got a Canon digital SLR and was hoping to download some pics:cry:cry
Any answers????
Hmmm, would the cable that I use on the video camera work OK if it's other end fits in the camera???
Nothing is going to explode on me is it???
fatboy 路
Wrong Size ?
A firewire cable (Sometime called 1394) looks a bit like a usb but is a different size.
Have a look in the camera maual and see if it is 1394.
NERDS ??? - oh you mean everyone but me - that ok then 馃榾
Brad 路
All USB ports are the same these days. If you have spare ports I am guessing they are not USB.
If you have a USB port and have your Video plugged in then you can unplug it and put the camera USB cable in there while the computer is on.
What do the spare ports look like ? Do they have pins or what ?
jenz58 路
Hmmm, let me check with the torch!!!
I've been sitting out side and thinking about this one馃檪
Geeks then Steve馃榾
jenz58 路
Not pins in ports and don't need pins
But none of my spare ports anywhere match the connection馃檨
helterskelter400 路
hey
find the chamera on the net & link a pikki of its cable or its stats/details & someone should be able to work it out...
jenz58 路
Hmmm, OK I've ben into Port in Device Manager and I don't seem to have USB listed. Would it be??
OK I'm not at this sort of stuff a lot! Only moments like this馃檪
jenz58 路
Here's the link to the camera
http://www.canoneos.com/digitalrebel/
Interface cable IFC-300pcu ? Is this the one?
helterskelter400 路
Huge Range of Standard Accessories + Software
- Dedicated EF-S 18-55mm f/3.5-5.6 optimally matched to the imaging area of the EOS 300D CMOS sensor offering a focal length equivalent to 28-90mm in 35mm format with compact size and high quality
- Battery Pack BP-511, Battery Charger CB-5L, Neck Strap EW-100DBII, Eyecup Ef, Camera Cover R-F-3,
USB Interface Cable IFC-300PCU and Video Cable VC-100
- File Viewfinder Utility (Win/Mac), ZoomBrowser EX (Win), Image Browser (Mac), PhotoRecord (Win/Mac), PhotoStitch (Win/Mac), Remote Capture (Win/Mac) and Adobe Elements 2.0 (Win/Mac)
usb - plug's gotta fit somewhere
try it again, upside down & inside out
jenz58 路
I know it should fit somewhere!!!馃檨
My system is not that old so sorta should have everything. I installed the card for the video so can do this one if needed
Maybe I've had too much sun today, and should sleep:sandrine
Damn I can never go to bed with something like this defeating me!!!馃槧
OK I'm gonna stand on my head and try it:thumb
jenz58 路
I've tried every which way and no luck.
I mustn't have a USB port or something else is using it??? Again no USB port listed in Device Manager?
What do I need to get, and I'll go get it???
Thanks:thumb
fatboy 路
The very last group in Device manager should be:
"Universal Serial Bus Controllers"
helterskelter400 路
usb plug -
should go into puker
helterskelter400 路
usb plugholes on puker (the two on left. serial plug is on right)
if any plug is already in one of these, unplug it & get your camera plug in it...
helterskelter400 路
like this eh fatmeister
jenz58 路
Thanks!!!!
Have two run and take Dr L for a major standard service. Was going to have a look tonight
Just looked at device manager again and I do have USB controllers working馃檪
Brad 路
You may have the mouse plugged into it and only have one on your board.
jenz58 路
That's what I've been thinking, cos I don't have many things plugged in back there and no spare USB ports, argh!!!
I'll be back, have dinner cooking!!!
So glad I used the Chrissy tree smilie, it makes finding this sooooo easy!!!馃榾
KOM123 路
As long as you have one USB port you can always buy a USB hub to add more connections 馃檪
For example:
http://www.dse.com.au/cgi-bin/dse.storefront/3fa8f3b1022280c2273fc0a87f9c0758/Product/View/XH0380
I'm not endorsing the above product, never tried that brand, just knew I could find a picture at that site that might explain a little better what I mean.
jenz58 路
Just found my scanner in the USB Port!!!!!:bounce:bounce:bounce
Now it's so late. Too many distractions tonight/ getting used to daylight saving
But tomorrow for sure now:thumb
Why did they put only one USB port in the puter?:jesus
fatboy 路
one is a bit odd.
I have a hub here that I dont use any more (New laptop has four ports), so your welcome to it.
馃榾
jenz58 路
Wahoo, in the daylight I could see I had a spare port!!!!:bounce:bounce
You were right Steve 馃檪
Pics are downloaded and I'll play with them tonight when I get home:thumb
