hey
can someone tell me if the kombi EFI system use an in-tank EFI pump or an external inline EFI pump?
rhys
kombi_kid 路
Aussieveedubbers 路 Tech Talk
https://forums.aussieveedubbers.com/threads/15432/kombi-efi-system
kombi_kid 路
kombidaze 路
vw59 路
kombi_kid 路
Rota_Motor 路
Bizarre 路
Andy 路
Rota_Motor 路
vw59 路
amazer 路
Rota_Motor 路
thanks amazer, but I have been told by the previous owner it was around 1900-2000 cpacity motor, and it was from his old baja, also on this forum, people have said old buggy boys used the big capacity motors, with single port heads and single carb, as it kept air velocity up and gave extremely high lowdown torque, but bugger all topend, which is apparently good for a buggy, and is exaclty how this beetle drives.amazer wrote:Rota, from the picture of your engine you have posted before it is 100% certain not type 4. Im also near 100% certain that it is not near 2 litres in capacity cos you wouldnt do that with single port heads.
You cant use the kombi injection. If you were to fit a type 4 engine into a beetle you would have to convert the cooling system to upright and then the manifolds wont go on. Theoretically you could use everything else if you made your own manifolds. However its a single throttle body system and to make manifolds that go over the altered cooling would mean they are extremely long and would look messy.
KruizinKombi 路
Menangler 路
Rota_Motor 路
