hey all, just wanted to know if you have to have your car runing for the flasher can to work? like i thought it worked with just the ignition on...but...
i bought a new relay from mick motor's and it allows the indicators to turn on...but they wont flash...馃槧<--i'll be like this if its the wrong one
jonno
kombi_kid 路
hey
it should have 3 outlets make sure u have the right wires on the right connectors!!! check ur manual for the right wiring direction!!!
rhys
jonno-t3 路
yeh its got 3 pins but it actually visuall looks different...and i'm pretty sure the wires are around the right way...cus the lights come on just dont flash...
jonno
vw54 路
If its 6 Volt start the engine and it should work.
Please supply more info when requesting a problem fix.
jonno-t3 路
its a 71 type 3 square...its 12 volt and here is the relay i bought..
jonno
pi22api22a 路
:alien
flasher did not work in my 73 kombi either, it fixed itself, accidentially left the hazrd button on all night, woke up in the morning and (you guessed it) all the blinkers had fixed themselves (Kombi Gnomes?),
Is the connection a good one or is it loose ? found mine to be loose (prob from vibration), try borrowing a plug from a mate, or,,
let the Gnomes do there job (leave them a beer or two)
Dave
robnjo 路
so have you started the motor yet... I now old audi stay on and not flash when the key is of.its a safty thing,at night if stuck on the side of the road.
rob
jonno-t3 路
OHHH!!! it just triggered in my brain...it must be because of the safety mechanism. when the car is off, if i put the indicator lever left, the right side marking light comes on...and vice versa..
so..i think the flasher only works when the car is on..cus then the safety thing wouldnt work..
....i think thats righ anyway....
