slowly getting down to business on our two beetles body and interiors nearing completion and now looking at engine options keen to do it all myself as i want strong motors that i know how they work . looking at fuel injection as twin carbies seem expensive and complicated. want to know if there are aftermarket fuel inj or maybe if vw type 3 or kombie fuel injection can be fitted probably looking at cap some where between 1680 and 1916cc. going to do total rebuild myself as much as possible . got two beetles to do first one warm for my gf second one hot for moir. really dont want to go and buy complete packages as i want to know how these things work and have more time than money. any ideas?? the cars are are 1976 roadster con vertible (warm) and a 1971 s (hot:alien
Do a search on 'aftermarket EFI'. There is a biig discussion on this at the moment!
amazer ·
If money is your problem then stick to carbs. By the time you buy manifolds and throttle bodies, the ECU, tune it up... It will cost you more than a set of carbs.
kombi_kid ·
u reacon carbies are a hassel and expensive u obviously havent read anything about the fuel injection side of things!!!
need atleast $2K for a good microtech injection system then ya need manifolds run return lines for overflow set up a extra oulet in ur fuel tank no to mention all the wiring etc!
not tryin to scare u away but ur better of buying some kadron carbs for ~$450 and they can handle pretty well upto around 1916cc alright
rhys
vwrallycar ·
fuel injection may be expensive 1st up but consider not having to tune it again!!!
i got so tired of tuning the twin carbs
Menangler ·
Whats to tune on carbs?
once they are jetted and the linkage is set right you shouldn't need to touch them, I haven't touched my twin 40 Dells on my ute for over 3 years.
Mad Manx ·
I've looked seriously at doing the conversion and have priced some of the componets needed:
Microtech with hand controller $1150
Camira throttle body,injectors,
pumps etc $200+(from the wreakers)
Manifolds $?? (free for me- bro's
an aluminium fabricator)
then theres the hours of design and fitting involved- microtech hand controller allows u to tune it yourself. If keeping the original motor isn't an issue I would do as Wes and others have and go for a motor made for injection with all the hard work done for u. Personally I'm looking at using a kombi 2lt FI and converting it to an upright motor (altho size is an issue in a beetle using a long block).
ratty 63 ·
Sounds similar to the prices that I had found, except I like the look of the ACDelco computer (from a GM) with the live-update mod ($1100) ... laptop tunable, able to save and load all settings (ie: have a fiddle with the settings and then recover the working ones when you stuff it up! :P ) Also has a 'self learn' function to help set up fuel maps - great for dummies like me! Ok, so you have to factor in the cost of a laptop if you don't have one but that is not an issue for some of us (and second hand ones are not that expensive)
Have a look at the thread mentioned above every now and again. I will be posting pics and details as my system comes along....waiting for the T1 twin port casting to be modified to suit injectors...😀
