Aussieveedubbers 路 Offroad V-Dubs
Buggy Wiring Diagram Wanted
https://forums.aussieveedubbers.com/threads/15955/buggy-wiring-diagram-wanted
Andy42 路
I need a basic wiring diagram for a manx or simmilar. No frills just the important stuff馃檪
Brad 路
you should join the Manx Club then ... oh thats right you have :P:o
Brad 路
1
Brad 路
2
handycam 路
brad u r a legand now i have the digram i need and i dident have 2 ask :thumb and the off road secton grate thinking
Brad 路
Glade I could help. I have them in bigger file sizes if you want them clearer as well.
bugggy@hotmail.com 路
Buggy Brad wrote:1
where's the voltage reg in these pics? can u do with out?mmmmm
Brad 路
on top of generator
68AutoBug 路
That is a good diagram Brad, it looks like it uses the same fuses as the beetles do... and VW switches..
I rewired My Sons girlfriends Baja 69 beetle and they wanted toggle switches in the dash, so thats what they have, no VW switches at all, apart from ignition & blinkers & horn....
I thought many buggies would use toggle switches Brad ... as You can get the rubber covers for them so they are water proof too..
I have a few small toggles with the rubber caps under My dash.. with some telltale small lamps in the dash...
so You know when the electric fuel pump is turned off...
Green light is On, and the engine can be started...
No green light.. No start...
Well thought out..
Brad 路
no switch you mention is water proof, they all have the same weak spot which is the back of them, thsi makes then suck in a bauugy / baja.
I use VW switches as I have found them to be the best. I use kombi ones most of the time as they are easier to get
Mad Manx 路
You guys all rule:thumb:thumb:thumb
Its amazing I just logged on to ask this very same question
and here it is with all the answers I needed馃檪
